Motec, educate me please...
I did my share of reading here but I am still unclear about the whole setup.
Thanks...
400hp is achievable with a lot of work to the motor.
It really depends on what you are after... the best bang for the buck is a custom chip from steve (rennsport systems in OR) and an exhaust to match.
it can be a black hole if you go in open ended.....
Companies like 9M have put together an engine package and rather than working with a factory ECU that presents challenges in programming, limited to a few people who have written code to access the programming, have chosen a MoTeC ECU. It is the engien package that makes the power, and the ECU that allows them to exploit it.
Are there other ways to acomplish the same thing, obviously yes.
Thanks...
Motec is just the ecu, it is what you can and do do with it that makes the difference. We remove the restrictive factory air flow meter/airbox, run Alpha-N control (throttle potentiometer vs rpm) with MAP correction & fit larger injectors. With this set up we usually see around 30hp gains over the best tuned equivalent Motronic (standard) engines (see graph). We charge a fixed price of £3495 (+taxes) for the 9m conversion fitted and mapped.
The installation purchased will very from installer to installer, all I can say is be wary of a Motec installer who has no Porsche experience and does not recommend changing the fuel injectors and intake system....
Any naturally aspirated engine will be a lot less stressed than the same hp supercharged engine, simply because it is not developing extra power to drive the supercharger to end up at the same result. N/A engines also do not have air intake temperature issues either.
The major disadvantage with Motec is that it does not run an integral knock control system and therefore you need to ensure that you always run the engine on the fuel it was mapped for. We are looking at having a Motronic derived stand-alone knock control system designed to use in conjunction with Motec and other ecus, but in the meantime there are knock warning systems already available which provide an effective warning light display.
Can't say any more that has not already been said and I'm sure everyone else feels likewise...
I promise that this will be the last I say on this !
The 964 M2.1 DME is an old system running a Flap Air flow meter. Not a huge deficeit but these days , not ideal . The 964 runs injectors that are just adequate in flow size for standard bhp ,so represent an issue .
The 993 system M2.1.1 was moved up to a Hot Film air flow measurement + throttle pot acceleration . Air flow is more than adequately covered .
( A slightly larger Air mass unit is used on the 993tt ! )
The 993 injectors are ok for flow rate but could , maybe take a little more.
Both M2.1 and M2.1.1 both have proper knock control systems and O2 part load/idle fuel control . This means that a correctly mapped system has no need for repetive fuelling adjustment like Motec and other throttle pot driven systems.
From all these factors I believe that a 993 M2.1.1 sytem is the best DME / Motec update on a 964 .
Unfortunately , to go with this is a tuner who can install the system and has access to DME calibration .
I think that is why the Motec ,etc sytems , which are so much easier for the average tuner ( THIS DOES NOT INCLUDE COLIN !!! )come across as a good choice .
Like all this stuff , the factors involved can be argued / debated for ever !
Its maybe worth looking around and checking prices/difficulty to make a decision.
My 964 went 993 etc many years ago so perhaps I am biased !!!!
( Oh , and I used to remap all the Porsche range on a daily basis , including 959/962 !! - but not now !!!!!!! )
Geoff
KS400200,the oldest 964 on Rennlist,unless you know differently !
Is it true that you are no longer doing Motronic remaps for the 964?
The only other aspect I forgot to mention is that Motec comes with narrow band O2 control like the Motronic ecu, however it also has full wide band control and datalogging available as an upgrade option.
