C4 to C2 conversion
#31
Originally Posted by Marc Shaw
There is one in Edmonton that I hope to get to this summer -- is that closer for you?
Marc
Marc
#32
Originally Posted by puma1824
This damn article prevented me from selling my car...buyer backed out last minute because of it.
#33
When you sell the C4, what are you going to replace it with? A C2?
#34
Originally Posted by jjbunn
I enjoyed your 964 Web site.
#35
First baby on the way...so I "was" going to the dark side and get a BMW M3
My 7 year old still finds it plenty big enough, too.
#36
jjbunn, when did your 7 year old start using the rear seat belt without the car seat? I assume that's what you do now. Did you use a booster seat in between the car seat and the belt?
#37
#38
Marc
Marc
Rod
#39
On a recent 5 hour plane flight I was bored and looked at the wiring issues of converting a C2 to C4, and it's neat that the process is actually quite simple thanks to Porsche's wiring. By purchasing a C2 ABS unit and the plug cut from a C2's harness, it is quite easy to remove the PDAS plug on the C4 and splice in the C2 ABS plug to the proper wires. That would permit the use of a C2 ABS brain with all functionality. After plugging off the hydraulic accumulator feed to the solenoid block, the extra C4 stuff can be removed: accelerometers, control unit, dash switch, PDAS solenoid block and all hydraulic lines to the transmission. Remove the tranny, drive shaft, front differential and CV's, and just plug in a 2wd 5 or 6 speed tranny and change the front axles - complete! It always seemed hard to manage the electronics, but it's not.
parkertseng (08-15-2023)
