First oil change, pretty easy.
Originally Posted by Indycam
"First oil change, pretty easy."
If it was pretty easy , you musta done it wrong .
I've never had a car or anything else that is such a pita to just change oil on .
I've changed oil in a boat diesel , down in the bilge , that was nowhere near such a total royal pita .
Originally Posted by kusee pee
I'm also a cheap skate and would love to change it myself. But I'm also a lazy b**stard. Cheap and lazy are not happy bedfellows!
Congratulations on a successful oil change, I find oil changes to be kind of a zen experience (I take my time and enjoy it).
Did you center the oil level gauge with 11 qts of cold oil?
If yes then you may have overfilled a bit since the oil will expand as it warms. I find that with my car, 10 qts refill is just right.
If you see a non-zero reading on the oil level gauge at, say 2,000 rpm or above after the oil has warmed up, ie. when you are cruising along, that's a sign you may have too much oil in there.
Ok Folks,
I feel like an absolute idiot. I've changed the oil in my previous 993 many times and the 964 is so much easier, but I'm having a problem with identifying the right oil filter part number. Following are the details:
Car: 1991 964 C2
Oil Filter Part Number: 944 107 201 03
- This filter does not fit my car
- Consensus on Rennlist and my PET and Porsche Dealer says this is the correct oil filter part number
- Pelican Parts says this part number is for the 964 Turbo - not the C2
Pelican doesn't have a Genuine Porsche Filter part
Pelican does have Mahle 930-107-764-01-M67 for the C2/C4
- This filter looks like the one I removed (but I cannot confirm because the part numbers have rubbed off the filter I removed - I'm going to follow-up with my shop that did the last oil change for me
The Porsche Filter 944... is thinner than the Mahle I pulled off
I just feel like an idiot and am wondering if others have experienced this too or if there is something 'unique' about my '91
Anyone know if there is an actual Porsche Oil Filter or do I need to stick to the Mahle?
Thanks,
-Skip
Car: 1991 964 C2
Thanks,
-Skip
Ok Folks,
Car: 1991 964 C2
Thanks,
-Skip
Car: 1991 964 C2
Thanks,
-Skip
The 944 part you have fits a 964 turbo but not a n/a 964.
Yeah, it's the same filter from '72- through 964s for all 911s.
Back to that "to do" list posted when this thread was new. Hilarious to say that using the A/C will make the engine run hotter. Likely for any deck lid condenser mounted car (e.g. a torsion bar car), but when they moved that to the nose............how's the car going to run hotter? Oh, driving the A/C compressor is going to so overtax our marginally designed engines to the point of failing?????? Uh huh...........
