My 993->964 backdate project
04-26-2007, 11:21 PM
Looking good. This will be an interesting project to watch.
04-26-2007, 11:33 PM
Keep 'em coming! Going to be pretty cool to see the progress.
05-03-2007, 12:50 PM
Body is finished
The body is mostly finished!
05-03-2007, 02:14 PM
05-03-2007, 03:03 PM
You're moving right along with this. Will you be able to run wheels with the correct offsets for those wide fenders or are you going to use spacers?
05-04-2007, 12:38 AM
Chris
I am not sure what wheels to run yet. I tried a set of standard 993tt wheels et52 front and et40 rear. The rears actually fit perfect but the fronts are way off. The fronts would need a 20mm spacer to put the wheel in the correct position.
05-21-2007, 06:25 AM
Ready for Paint!
06-15-2007, 01:12 PM
Professor of Pending ProjectsRennlist Member
Looking good. Great thread. Keep those photos coming.
07-02-2007, 11:55 PM
Did you move the lower front suspension bolt position to the outward bolt holes that Geoffrey mentioned earlier? You also rotate the top shock mount 180 degress and this gives you the turbo width on the front and should eliminate the need for the spacer. Jim
12-13-2007, 01:09 PM
How is the project coming along? We have not had a post since July. I would love to see an update!
12-13-2007, 09:56 PM
The project is finished. I will get pictures up ASAP.
12-15-2007, 09:39 AM
Here it is!
12-15-2007, 09:59 AM
Another picture.
12-15-2007, 10:40 AM
AddictRennlist Member
Wow! Very cool!
12-15-2007, 12:03 PM
More pics please! That came out great!
