Aftermarket Knock Sensor For A Turbo
Hello,
I'm looking for a good aftermarket knock sensor for a turbo.
I was told that the Andial system is the way to go any input?
Also so is this a pretty easy DIY project?
I have a Haltech O2 wide-band in the car. This will allow me to check if the car is running to rich or lean. But I would think a good knock sensor would retard the timing if it detects pinging.
Originally Posted by jimq
How is the rebuild coming?
Hey Jim the motor is done. Everything is starting to come into place.
What power steering system are you running ?
How do I check what power sterring sytem I have?
Does it matter for a Knock sensor?
Thanks again.......
Thanks again.......
Indy, I have a new Euro RS rack in my car, but it is wired to use a GT3R electric power steering pump. I have an output from the MoTeC ADL that outputs a variable duty cycle signal to a PWM controller which will provide the power steering pump between 2 and 12 volts depending on the wheel speed and steering angle. I have found that I really don't need power steering, although I may install it at some point just to try out the electrics.
I wish to learn about
"electric power steering pump"
"variable duty cycle signal to a PWM controller which will provide the power steering pump between 2 and 12 volts"
"wheel speed and steering angle."
know any place for me to read up ?
