Anyone run max front camber for street driving?
When I replaced my shocks we took a slightly unscientific approach to geometry: Spring perches at same height as before, and as much front camber as possible. Can't do that in a 993..
The car is great, pointy and much less understeer unless very low traction conditions - when the wheels don't grip enough to roll into the camber.
At parking speeds, however, the front tyres seem to be pushing and scraping a little, and more than once I have felt that a steering input that was fine for my old setup sends me into a feeling of imminent body-roll oversteer as the front grips suddenly I guess I need less 'forearm shove' now..
Anyone any inputs? Am I going to wear my tyres weirdly?
Johhny ,
Got any alignment numbers ? I guess 3-4 degrees of negative ? Why cant you do that with a 993 . The front ends are the same .
Geoff
Geoff
Hi Geoff.
No numbers - I don't have the tools -but not as much as that I don't think. IIRC cup cars came with negative 2.6.
My reference to 993's was their apparent sensitivity to alignment with the multi link rears. I also wanted to mention a 993 in my 993'rd post!
Hows the weather in Halifax?
When I replaced the stock suspension on my car and lowered it to RS height it had -3.5 and -3 on the front wheels. Im pretty sure it would have worn the tires on the inside edge in a short time. My toe and caster were also out and even though the car cornered like a slot car the handleing felt a little off when going down a straight road. You really need to get an alignment. I had mine done at European RS spec by RUF in Dallas and I love it. The car handles much better than stock and will now track straight and true and Im not worried about ruining my expensive tires.
Thanks for the inputs.
I'm trying to find out from searches how much maximum is. So far it looks like +/- 1.7 deg? Does the maximum just depend on the wheel carrier, or will different strut/spring combinations change this too?
My current tyres are on their last legs anyway, but I guess I can't get away without a professional 4 wheel alignment after replacing springs and shocks. Trouble is the car seems pretty good already, if a tiny bit twitchy on fast straightlines..
Johhny,
Weather here is great . To be honest I am amazed at what you are doing .
Without a real 4 wheel alignment you have to be wasting tires and time !
Maybe this is just fun to see how quick you can destroy the tires !!
Be careful to keep it on the road .
Geoff
Geoff
Super Duper Moderator
I have -2.5 front and -3.0 rear but do as much track time as possible.
I find it a little squirelly at moderate speeds but it really turns in easily and seems to settle down once you get above 70 km/h - below that it is certainly darty.
I would think that there is no benefit to those types of numbers for a street only car as tire wear is certainly increased (esp. rear).
Marc
Marc
Originally Posted by ThomasC2
Is that a C4 thing?
I needed -3 to fit the 18" wheels in but found -3 on the front made the dartiness at speed more pronounced - reducing it to -2.5 reduced the dartiness without impacting on turn-in or cornering feel.
I don't know - perhaps it does relate to being a C4.
Marc
