Indicator stalk
I have a minor problem with the indicator stalk. Turn left (down) works fine but when turning right I have to hold the stalk up (doesn't click in to place).
Has anyone taken the unit apart to fix something like this and if so what do I need to know and what tools will I need?
Alternatively if I have to fit a new or used unit, can I get the 3 stalk version and wire up the OBC (obviously mine wasn't specced with this).
TIA
Steve
TIA
Steve
Mark, brilliant! That looks just like what I need.
From what I can see, opening up the unit to fix the problem with the stalk could be a nightmare and lead to the car being off the road for a while if I mess it up. So that's out. Replacing with a new assembly, pre-purchased before I start disassembling, would be the best option.
I see you replaced the assembly like for like. Yet, the keyed plugs give me the hope that the OBC wiring is already there and could plug straight into an assembly that has the OBC stalk (mine is just turn, lights and headlight wash)? I guess from what Steve says this gives me further hope. Steve, did you not have headlight wash before and just bought the upgraded assembly and plugged it in?
Steve
Steve
Glad it looks like an easy fix, I did feel bad that I could't sort that for you mate.
Originally Posted by kusee pee
I can't believe you've broken something on it already
Super Duper Moderator
....Yet, the keyed plugs give me the hope that the OBC wiring is already there and could plug straight into an assembly that has the OBC stalk (mine is just turn, lights and headlight wash)? I guess from what Steve says this gives me further hope. ....
Marc
Waheey! It looks like I'm going shopping! I'll check the price at my local Porsche parts counter but even with shipping costs I doubt if they'll beat the £155* that Automocion.com is charging for this little beauty.
*Helped by a very favourable $Can to £GB rate at the moment.
I found one exception to using the same harness in all cars. The harness for the top rear deck is different depending upon whether you have a wiper or not. Up to the last extension harnesses, the principal wiring harnesses may be the same.
I did not have headlight washer option. I bought all the parts and installed it. I had planned to drill my own holes in the bumper plastic when someone hit my front bumper and it had to be replaced. So I chose the replacement to have the pre-drilled holes.
Hey Steve, mine is a white C2. And I will be adding the rear wiper and also removing the CHMSL when I change rear windshield. And I am adding those side markers I see on yours.
![burnout](https://rennlist.com/forums/graemlins/burnout.gif)
At the moment I'm just sorting out the basics: new continental sport contact 2s went on yesterday, getting new wiper blades, some interior bulbs and spare V-belts tomorrow. Then of course I need to get hold of the turn stalk, a new bumper support bar to replace the missing (corroded) one at the rear and a headlamp rim.
Then it'll be on to the upgrades: clubsport steering wheel, strut brace, clear turn signal lenses, RS brake ducts, 3rd brake light/spoiler and on, and on
Oh and forget to mention that tomorrow I'll be fitting the Rennlist sticker that I just got in the mail
I'm adding the third brake light spoiler onto the engine lid also. I prefer that to the the later version mounted on the glass.
Also, what are your thoughts on exhausts? I've got a standard cat and primary silencer plus a G pipe. I can't help thinking that the latter is all show and affects go, so was thinking of putting a sports SS silencer on.
Thanks to Marc's DIY article about replacing the turn signal assembly I've got fully working indicators now. As mine (like many UK cars) doesn't have an air bag there were some minor differences.
1. There's no need to wait after disconnecting the battery. Just get straight on with it.
2. The horn ring is part of the steering wheel hub so need to worry about removing that.
3. The assembly has a copper contact strip on the indicator assembly. I had to gentle wiggle this off and fit it to the new assembly (this is needed for the horn to work).
4. The new assembly I bought had the OBC stalk aswell as I hope to get this hacked and working. This meant I had to lengthen the hole on the bottom plastic cowling to accomodate the extra stalk.
Now I just need to find out how to activate the OBC (the wires plugged straight in but there must be something else I need to do to get the display activated).
