WTB a 3.6 Cylinder
WTB a 3.6 Cylinder
Hey guys I'm in the market to buy a single 3.6 cylinder.
Height code #5
Bore code #2
I have a cracked #4 cylinder in my 1992 964.
Many Thanks..........
Height code #5
Bore code #2
Indy
Originally Posted by Indycam
What style ?
With groovy , without ?
With piston , without ?
Turbo piston , or na piston ?
Group code ?
Group code ?
Indy I'm going to print out your questions and take it to the tech to ask him.
Thanks for the reply.
Regards,
Eric
Pictures Added
ReLi
Id like a photo of the old one , can do ?
Here you go bud. Check out the crack it goes from the top of the cylinder to the bottom. I'm trying to find the height and the tolerance #'s on the cylinder. I notice it has 4 + so I'm guessing that is the Tolerance #. I called the original motor builder and he said it is a stock 3.6 C-2 cylinder.
Ok, that is a post 91 style 3.6 cylinder. The only time I have seen a cylinder cracked from top to bottom was when someone installed a waste spark ignition system and swapped wires so the engine fired at the wrong time ie significantly early by 120 degrees and detonated the engine. Can you post a more detailed picture of the top of the crack from the inside of the cylinder?
The height group with either be 5 or 6 in a triangle with a second number next to it identifying the bore group (0-3). It should be on the base of the cylinder.
More Pictures
Here you go.
If these aren't any better P.M. me your e-mail and I'll e-mail you some better pictures.
Thanks again.........
Looks Good
Originally Posted by jim dorociak
piston ok? what about the cylinder head? I have never seen this before. Jim
Jim the piston looks OK and the head also looks good. What a mess.....
Info
What style ? 3.6 IS THIS WHAT YOUR LOOKING FOR??????
With groovy , without ? With
With piston , without ? With out
Turbo piston , or na piston ? With out
Group code ?
Group code ?
THANKS BUD.........
