Is is the clock problem?
Could someone confirm the below statement to be true / false / probably true etc?
thanks
Garry
On starting the car:
- The ABS light is lit
- The dash backlights are dim
- The heater/demister fan runs slow
On reving the engine past 3000 RPM once, the alternator kicks in and the above symptoms are rectified, however the ABS system does not function on hard braking.
This is a symptom of 'bad solder joints' in the clock!
thanks
Garry
IHI KING!
Your symptoms sound to me like your alternator or battery is starting to fail. I would put a volt meter on battery to check. With the engine off, you should have 12-12.5 volts. With the engine idling, you should have 14-14.5 volts. If you don't have 12 volts on the battery, then the battery is failing. If your battery is good but you don't have 14 volts with the engine idling, then your alternator is failing.
By the way, I would also look for any corrosion on the battery terminals and cables.
Battery does need replacing, but the Alternator is fine - according to the nice AA man.
Found this --> which answers my question. True.
https://rennlist.com/forums/964-forum/315618-pdas-abs-light-on-no-charging.html
Does anyone have a spare - or want to sell me a repaired/working one. I don't have the tools/skills to DIY this.
thanks.
Garry
thanks.
Garry
It doesn't entirely answer your question. I've never heard of it also causing dim dash lights (mine didn't) or slow demister - and it shouldn't affect your ABS working either.
I had almost the same symptoms on my C4. The alternator would now and then not kick in at all before i reved it past 3000rpm. I had the PDAS light and the ABS light on + the emergency light. Resoldered the clock and haven't had the symptoms since.
Odd Gunnar Moe
Norway
Odd Gunnar Moe
Norway
Hi Garry,
Not sure about the dim lights but the alternator not kicking in until 3000 rpm is definitely a clock issue in my experience. Does seem a weird link I know but it's apprently due to some part of the clock electrically exciting, or not in this case, some part of the alternator circuit (as you may have realised I'm not an auto electrician!).
I had this issue myself a while ago and rather than re-solder the connections myself I picked up a replacement clock from a 993 (identical to 964 clock) on Ebay for less than £20.00. Only had to wait a week or so until one came up for auction.
Good luck,
David
Good luck,
David
Garry
Strangely enough i re-soldered my clock last night as i too was suffering from the alternator not kicking in untill after 3000rpm. All the symptons you describe, (except your abs problem) are now sorted so the clock can definitely be responsible for the problems you describe. I was like you and unsure if the clock could be the fault but it was so the answer to your question is Yes, its true.
Regards
Mark
Regards
Mark
Originally Posted by aeroman
Can someone explain to me how the darn clock can bring a fine german engineered car to its knees?
Obviously they forgot about those pesky soldering irons though.
http://www.porsche964.co.uk/
The details including photo's can be found on the above site. Easy to follow instructions and doesn't take that long.
An alternator needs a current draw to "excite" it so it begins to produce power. The function of the alternator light (or battery light) is to draw approximately 250mA of current so the alternator is excited and begins to produce current. The excite wire is also wired to the ABS system and provides 12v power so the ABS controller knows the engine is running.
