rattle sound behind rear passenger side wheel well
Hi,
I have a 1990 C4 and recently after idleingfor about 5 minutes, I hear a rattle at the rear passenger side of the car. Seems to be located in or around the muffler part thats behind this wheel. Any help would be greatly appreciated!
Depending on what is wrong - if the muffler baffles are loose/broken, no harm will be done except to your ears. If the heat shields are loose, you may lose the bolts/shields on the road.
Maybe its time for a secondary bypass (G-pipe)? It will transform your car.
Damn mine has just started making a horible rattle on the Right hand side(uk drivers) will see if I can take a look this weekend. hoping it will be a loose braket or something on teh exhaust as I have just ordered a primary bypass so cant fit a secondary by pass as well.
