Where is the outside temp sensor?
My On Board Computer Reads -40 °C which I guess means some problem with the sensor. I was traing to locate it somewhere under the front bumper on the left side but no success. I have removed the blinker and then the lowel spoiler plastic covering but did not find it.
Where should it be located? And how are the wires going?
P.S. My car is a 1991 964 ROW Tiptronic coupé built in 9/1990
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Ciao,
Adrian.
kos11-12 (02-28-2024)
Thanks guys, that will be the problem. There are aero mirrors and they react exactly the oposite - move the joystick left, mirror goes right. Somebody may have mismatched that.
I learnt this from "THE BIBLE"
I mean, Adrian's book...
Burgled
Originally Posted by ChaseN
Wait, onboard computer? What am I missing? Where does the temperature read out on your car!!?? Am I on the 996 forum?
Computers are not needed. If its cold when you get in the car you know the outside temp is low. If on the other hand its hot when you get in, you can guess the outside temp is high... simple.
The thing I like most about the on board computer is the digital speedo. It reminds me of the 996. There is also a big digital number on the tachometer and then an analog needle on the sporadicly numbered speedometer.
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Originally Posted by jimq
standard on a TIP option on a stick
Ciao,
Adrian.
Just another thing to go wrong IMO. Could be jealous cause i havent got one tho... I do like the idea of knowing the MPG. Does it also tell you how many miles you got left before filling up??
