964 Forum 1989-1994
Scantool Diagnostic 19 pin Plug
Old 05-02-2007, 01:38 PM
  #46
maurice97C2S
maurice97C2S's Avatar
Can I get 2 for Porsche Club GB too, please ?
cheers, Maurice
Old 05-02-2007, 03:24 PM
  #47
amfp
amfp's Avatar
Pls add me to cable list. Thx.
Old 05-03-2007, 05:04 AM
  #48
bawmnot
bawmnot's Avatar
me too please! - thx for this, great gesture
Old 05-11-2007, 10:34 AM
  #49
mojorizing
mojorizing's Avatar
I'm planning on making the plugs starting next week, and I'll contact the interested parties as I finish them.
later, Kevin
Old 05-11-2007, 10:41 AM
  #50
RicardoD
RicardoD's Avatar
If still open count me in.
All the best,
Ricardo
Old 05-11-2007, 10:51 AM
  #51
merrick
merrick's Avatar
I'm in if still available.
Old 05-11-2007, 10:55 AM
  #52
Danz C4
Danz C4's Avatar
Me, two please...
Old 05-11-2007, 10:56 AM
  #53
craig001
craig001's Avatar
Put my name on the notification list too,. please. I have a Bosch KTS-300 coming in from eBay. Seller ( a porsche shop in Ontario, Canada) claims it is set-up for p-cars. We will see when it arrives. TIA.
Old 05-11-2007, 01:21 PM
  #54
Jerry Garwick
Jerry Garwick's Avatar
Location: Prather, California: somewhere in the middle of the State
OK, I'm intrigued. I have been ingoring the RENNLIST for some time and have not followed this thread until today. Just what does the scantool do? Is it a substitute for the Bosch hammer?
Old 05-11-2007, 02:06 PM
  #55
mojorizing
mojorizing's Avatar
I quote from the scantools author DougB from this post Here
"The software can:
• Read/Clear fault codes for the Motronic ECU, air bag, climate control and PDAS.
• Run actuator tests for Motronic. This is a test that cycles the different actuators such as the resonance flap and fuel injectors. During the test you’re expected to listen for the actuators clicking on and off.
• Display values from the Motronic’s analog inputs such as the voltage from the air flow meter and temp sensors.
• Display the state of the Motronic’s idle and wide open throttle switches.
• Display Motronic’s actual operating parameters such as rpm and load. Practically all of the operating parameters are available but I believe the version of the software that’s currently out there has a limited list of parameters.
• Display Motrinic’s high/low range AFR trim values along with a live O2 sensor signal.
• Display the state of the PDAS traction control switch.
What it can not do:
• Bleed the PDAS system.
• Operate the transverse and longitudinal locks.
• Display ‘knock counts.’ This isn’t really a diagnostics feature. It’s implemented separately with a +12 volt pulse signal."
Here's a review of the actual Hammer from Dfinnegan Here
Old 05-13-2007, 12:28 PM
  #56
Laurence Gibbs
Laurence Gibbs's Avatar
Hi kevin,
please put me on the list too.
thanks
Laurence
Old 05-13-2007, 02:54 PM
  #57
jbs
jbs's Avatar
Please count me in too.
Thanks.
Old 05-14-2007, 08:48 PM
  #58
Jerry Garwick
I hesitate to join in on this subject due to my ignorance, but here goes. I have read in the May issue of Total 911 magazine, page 28 (out of Britian) that a company called Autologic is planning on releasing a pc version of the Bosch hammer later in 2007. Does anyone know how this will be different from the Scantool version? Please don't flame me if I asked a really stupid queston.
Old 05-14-2007, 09:09 PM
  #59
911URGE
911URGE's Avatar
Geez...I miss one issue and miss out on that little tidbit.
You still need a 19 pin connector to link your 964 to a laptop. I wonder how hard it would be to add all 19 pins for future use even if we are only using 4 today for the Scantool interface?
Old 05-14-2007, 09:42 PM
  #60
mojorizing
mojorizing's Avatar
Not all pins are used.
I think the next iteration of the scantool should be on a microchip w/ lcd display.
Quick Reply: Scantool Diagnostic 19 pin Plug
