964 Forum 1989-1994
993 Heat Exchangers on 964
Old 09-27-2006, 02:25 PM
StanAE86
StanAE86's Avatar
Default 993 Heat Exchangers on 964
I'm going to be trying to do the "flip the flange" modification to some 993 heat exchangers...for fitment on my 964. I have the exchangers and the cats off a 993 already.
I know people have done this, has anyone used the 993 cats as well? All the pictures I can find on the net (well, actually, only 2 or 3 pics), all skip the cats. I don't want to do that.
With that, does anyone have any pictures they can share with me, where they have cats and the muffler?
This is one company I know of that does these types of mods, but they don't have any pics using a cat:
http://www.instant-g.com/Products/Exhausts/993Exhaust/
http://www.instant-g.com/Products/Ex...Out/index.html
Thanks.
Old 09-28-2006, 12:06 AM
pete000
pete000's Avatar
I always thaught that would be a grteat mod. Not sure if the cats would fit though. Never seen it done.
Old 09-28-2006, 02:04 PM
SimonExtreme
SimonExtreme's Avatar
Don't know about cats but I would bet a lot of money that the instant-g set up would be LOUD!
Old 09-28-2006, 10:43 PM
Colin 90 C2
Colin 90 C2's Avatar
If you look on Pelican, there is a DIY on flipping the flanges.
I recently completed the flange flip and it was pretty easy, although I went through more than a few dremel cut-off wheels. I ended up buying an air die grinder and using diamond tipped wheels that are available from Harbor Freight for less than $20 for the tool and the wheels.
The hardest part was realigning the flanges for welding. Luckily, I had the engine out (still out).
I have been thinking of exhaust sytems and will probably go with compact cats and bullet mufflers.
Old 09-29-2006, 02:12 AM
StanAE86
StanAE86's Avatar
I heard you can grind out the inside of the pipe to break the OEM weld to the flange? Or did you just cut the pip and flip it?
Thanks!
Old 09-29-2006, 10:26 AM
Colin 90 C2
I ground down the weld on the interior of the flange and the header tube. I think it is a better solution. This way the flange is free to be positioned correctly. It also gives you a better welding area with minimal metal distortion.
Old 09-29-2006, 01:00 PM
StanAE86
StanAE86's Avatar
Thanks Colin. Let me know when you get the motor in the car and start trying to figure out how to make things fit...I think that will be the hardest part. Right now, I'm thinking of keeping the cats and running muffler bypasses instead. From the way the pipes run, it'd be a J bend into an exhaust tip. I'd rather get busted for no muffler than no cats in California.
Old 10-02-2006, 12:46 PM
964 C2R
964 C2R's Avatar
"I recently completed the flange flip and it was pretty easy"
Dear Colin,
Do you have any pictures of the result per chance?
Regards, Daniel Saxlid
Old 10-02-2006, 12:48 PM
robmug
robmug's Avatar
What's the benefit of this mod?
Old 10-02-2006, 02:05 PM
SimonExtreme
Don't ask awkward questions!
Old 10-02-2006, 03:30 PM
Gus
Gus's Avatar
more HP
Old 10-02-2006, 05:56 PM
Colin 90 C2
try this link
http://forums.pelicanparts.com/showt...eat+exchangers
I know there is another link on Pelican and I will find it for you.
Here is the definitive thread with awesome pictures
http://forums.pelicanparts.com/showt...hlight=993+hes
Old 10-02-2006, 07:23 PM
SimonExtreme
Originally Posted by Gus
more HP
I have heard this but based on data on other threads, is there really a gain to be achieved?
Old 10-02-2006, 07:44 PM
Colin 90 C2
Apparently most of the gain in hp between the 993 and the 964 is due to the exhaust.
The 993 HE's have a much better flow pattern than the crossover pipe associated with the 964 HE.
Much more like aftermarket headers, such as the SSI's that are popular with the 911SC's.
Plus it gives you the option of true dual exhausts.
Old 10-02-2006, 08:22 PM
SimonExtreme
Well, I stand corrected but looking at the figures Colin has produced, it doesn't seem to be the answer. I had thought it was the varioram but that while it gave an imporement over a 64, when it came to tuning further the 64 system was better.
Quick Reply: 993 Heat Exchangers on 964
