Regearing a C4 for street only use.
So I'll never, I mean never be able to use the car's 160 mph ability. In reality I'll never cruise beyond 90 or so.
So if I were to regear the tranny, what experience do any of us have with doing this with a street car? What kind of improvement can one expect to see for quickening off the line and around town usage. I don't want to do burnouts, I just was thinking that there is a lot of engine torque that could be better used.
I've been saving info on various gear ratios simply because I read an article on regearing the C4 for road use and my car has been re-geared.
Here are a few bits of info that I've collected. Not what you're looking for, but it's a start.
Gear ratios
<b>Stock Carrera 4 Carrera 2</b>
<b>speed vs rpm</b>
http://www.geocities.com/z_design_st...n_993_bit.html
<b>6800 rpm</b>
<b>Geoffrey's recommendations to a posted request for max speed 150mph</b>
<b>dougn</b>
<b>TonyTaylor</b>
near as perfect as I can imagine. However Iam not using the stock G50
box.<br>
if I had a 5 speed and was able to regear all ratios then I would pick
the first 5 of these or as near as possible and live without 6th.<br>
If all your ratios are short you waste time changing up and down, ideally
you need a good spread throughout the speed range your likely to be
using.<br>
If I was to critisise the stock box I would say 1st is way too low and
the jump from 3rd to 4th too much - the car just dies at this point
even with 300hp<br>
<b>Manual Transmission (C4): G-64, Synchromesh 5-Speed manual</b>
- 1st 3.500:1 3.500:1 (12/42)
- 2nd 2.118:1 2.059:1 (
- 3rd 1.444:1 1.407:1
- 4th 1.086:1 1.086:1
- 5th 0.868:1 0.868:1
- Reverse 2.857:1 2.857:1
- Final drive ratio: 3.444:1 3.444:1
- 1st 3.500 (12/42)
- 2nd 2.048 (21/43) -or- 2.059 (17/35) - chart not clear
- 3rd 1.579 (19/30)
- 4th 1.238 (21/26)
- 5th 1.000 (25/25) ~150 mph top speed
<b>speed vs rpm</b>
<b>6800 rpm</b>
- 1st 42 mph
- 2nd 72 mph
- 3rd 93 mph
- 4th 119 mph
- 5th 147 mph
- 1st 3.500 (12/42)
- 2nd 2.048 (21/43)
- 3rd 1.500 (20/30)
- 4th 1.200 (25/30)
- 5th 1.000 (25/25)
<b>dougn</b>
- 1st 3.5
- 2nd 2.4
- 3rd 1.77
- 4th 1.33
- 5th 1
<b>TonyTaylor</b>
- 1st 3.154 46 mph@6800 rpm
- 2nd 2.000 72 mph@6800 rpm
- 3rd 1.522 94 mph@6800 rpm
- 4th 1.241 116 mph@6800 rpm
- 5th 1.031 139 mph@6800 rpm
- 6th 0.829 173 mph@6800 rpm
box.<br>
using.<br>
even with 300hp<br>
- * Reverse: 2.857:1
- * 1st: 3.500:1
- * 2nd: 2.118:1
- * 3rd: 1.444:1
- * 4th: 1.086:1
- * 5th (OD): 0.868:1
- * Final drive: 3.444:1
i did alot of thinking and calculations on my re-gear for street use. the problems as i saw them were:
the 1 to 2 gap was huge really hampering accleration and general drivability
although 1'st was too low, i opted to keep it because i installed a LWF. i'm glad i did
fifth was too high. cruzing at 80 mph at about 3150 rpms. engine sounds comfortable at about 3500 or 3600 rpms....kind of lugging at 3100
2nd gear was too high for alot of the corners i drive
in alot of situations, 3 was too high and 2 too low
so, based on measured torque and horsepower i came up with the ratios in dfinnegans post. it was designed as a street/sport box. it would be good for tight twisty courses. cruze at 80 mph is at 3700 rpms and it tops out at about 148 mph.
i set-up the cruze rpm because anything over 80 (real mph) will draw the atten of the CHP (red porsche). so i can cruze along at 75 comfortably
re-gearing for track use would produce a completely different box (not a very good street box IMO)....without regard for the 1 to 2 gap, lowering 5th and spacing everything closer
if you're really going to cruze at 90, your 5th is good (3600 rpms at 90)....so you really shouldn't change anything
Bill,
it's a track or street set up?
Ciao
Paolo
Ciao
Paolo
Originally Posted by PAOLOP
Bill,
Ciao
Paolo
Ciao
Paolo
Reasonable top end
decreasing drops as you go up
reasonably sized drops
of course having the middle-upper gears closer, w/ smaller drops is nicer but it is also harder to accomplish w/ a 5 spd. while retaining a reasonable top end.
ideal gearing is going to be different for everyone depending on use and other mods.
a dedicated track car w/ race engine has differnt needs from a dual purpose car.
Thank you very much, Bill.
Ciao
Paolo
Ciao
Paolo
