964 Forum 1989-1994
Metal Master Brake Pad Question
Old 06-21-2006, 03:10 PM
Idoktr
Idoktr's Avatar
Default Metal Master Brake Pad Question
I just purchased a set of MM pads, but upon inspection there is no clip for the brake sensor wire? Is this true of all MM pads?
Old 06-21-2006, 03:30 PM
Heirsh
Heirsh's Avatar
I just put on a set of mm pads. There is a little slot, like the oem pads, for the sensor. I don't know what you mean by a clip? could you eleaborate?
Old 06-21-2006, 03:36 PM
Idoktr
Idoktr's Avatar
Default Here is the link with the photo
Scroll down the following page to Metal Master Pads and enlarge the photo. There is no place to attach the sensor....
http://replacement.autopartswarehous...20Set&dp=false
Old 06-21-2006, 04:00 PM
Heirsh
Heirsh's Avatar
Interesting. No its not true of all MM pads. I can give you my exact numbers when i get home if you like (on the pad boxes). I mistakingly got a set of the rears for the early style (their error not mine) and they also had a spot for the sensor. I would say you have the wrong parts if you want to use the sensors.
Old 06-21-2006, 04:03 PM
Idoktr
Idoktr's Avatar
Default I would appreciate the numbers
from your pads. I will then call them and get the right pads.
Thanks!!
Stewart
Old 06-21-2006, 04:48 PM
jimq
Burgled
jimq's Avatar
mine have the slots front and rear sets. Actually its the same pad all 4 wheels if you have stock 4 piston calipers
Just looked at that price! I paid less then $30 buying them local at a import car part store.
Old 06-21-2006, 05:00 PM
garrett376
garrett376's Avatar
I ordered mine through Pelican and they came with slots for the brake wear sensors.
Old 06-21-2006, 05:01 PM
garrett376
garrett376's Avatar
From the invoice:
Item Name Item Price Quantity Item Total
PEL-BP-2518M $41.55 2 $83.10
Metal-Master Front Brake Pads, 911 Carrera 2/4 (1989-94), Rear 911 C4
(1989-94), 911 Turbo (1989-94)
Old 06-21-2006, 05:05 PM
Heirsh
Heirsh's Avatar
still have your box garrett? pelicans numbers dont seem to correspond to anything pbr (metal master)related.
Old 06-21-2006, 05:06 PM
garrett376
garrett376's Avatar
yeah... I'll look when I go home today since I still have the boxes in the cabinet...
Old 06-21-2006, 08:55 PM
Heirsh
Heirsh's Avatar
Ok so I have both my boxes for sending back to pelican, but I dont know which is which. So i'll list both the numbers.
D 951 RM
D 552 RM
One is for the old style 2 pot rears. The other the correct one (or one of the correct ones) for the front and rear newer style brakes. Sorry I can;t be more specific.
Old 06-21-2006, 09:29 PM
Idoktr
Idoktr's Avatar
Default 552 is for the front, but
it lists it for the 84-89 model year??????
Old 06-21-2006, 09:41 PM
Heirsh
Heirsh's Avatar
Beats me. I tried to find info on the metal master types, but couldn't. If you found somewhere please let me know the url.
I can confirm that I installed my pads, with sensors, with no problems.
Love your car color btw. )
edit: I don't know for sure that the set I got by mistake is for the 2-pot rears. They look the same, but I jumped to an assumption. It could be that those are the ones you found listed for the late 80's fronts. In fact that makes great sense as I didnt know metal master made pads for the rear of the early style c2. So I;d say the other number is the right one.
Old 06-21-2006, 09:45 PM
Idoktr
Idoktr's Avatar
Default Anyone if the 84-89 pads will work?
Pelican sent me 2 sets of pads, both wrong. AutoWarehouse sent the right pads but no place for the sensors. Jeez>>>>>>>>>
Thanks for the kudo, I purchased the car because of the rare Oak Green Metallic color. Never seen one before, or since, around here.
Stewart
Old 06-21-2006, 10:16 PM
jimq
Burgled
jimq's Avatar
the set I bought local with the slot for the sensor is BA 088-1298M. Seems like the part numbers are all over the board on these pads. List $52.52 cost $29.78 local
Quick Reply: Metal Master Brake Pad Question
