What cat bypass are you using?
My cat has seen its day, and I really need to get one at this point. What ones are you guys using? Does anyone have a used cat bypass for sale?
Chris
Chris
i have one ....it's like new ...bought it from fabspeed
yes i think it was 375 new....i'd like 250 for it. i only used it for a little while then went to GHL headers
6th Gear
Be warned that the sensor will almost certainly not come out - heat etc helps it to seize in place so budget for a new replacement. I've just done this job on mine - straight forward enough though I had to cut the nuts off the exhaust clamp -rusted solid. Connecting the sensor inside the engine bay requires fingers about 12" long. Worth it though because it sounds even better than before and feels slightly sharper.
Is a cat bypass louder than primary muffler bypass? I have a G-pipe and have been on the verge of getting a primary bypass for even more sound. Should I bypass the cat instead?
I've actually tried both bypasses on the muffler and left the cat in, and it was "open track" loud. One muffler bypass and a cat bypass seems to be OK - too loud for some, just enough for others.
