Splitting Calipers pros/cons?
For anybody who is interested, here is a list of all the parts related to the calipers, and their prices in USD. (Parts numbers are updated to the latest revs)
FRONT BRAKE
DESCRIPTION PART # QUANTITY PRICE EACH
Connecting Line 951 351 971 00 1 $25.30
Expanding Sping 951 352 950 00 1 $26.50
Spring Plate Repair Kit 964 351 959 01 1 $16.31
Spring Plate Repair Kit 964 351 959 00 1 $16.31
40 mm set of seals 951 351 919 11 2 $21.65
36 mm set of seals 951 351 919 10 2 $20.61
40 mm damping plate 964 351 096 02 2 $3.39
36 mm damping plate 964 351 096 01 2 $3.39
Vent Valve 930 351 919 00 2 $11.02
Protective Plate Right 964 351 804 02 1 $15.59
Protective Plate Left 964 351 803 02 1 $15.59
Dust cap 930 351 927 00 2 $0.83
REAR BRAKE
Connecting Line 951 352 971 00 1 $42.41
Spring Plate Repair Kit 993 352 959 01 1 $16.31
Spring Plate Repair Kit 993 352 959 00 1 $16.31
30 mm set of seals 951 352 919 11 2 $19.22
28 mm set of seals 951 352 919 10 2 $19.24
30 mm damping plate 964 352 096 00 2 $2.93
28 mm damping plate 996 352 086 01 2 $5.22
Protective Plate 964 352 801 00 1 $42.35
So obviously you want to save as many pieces as possible on a caliper rebuild!
Kirk
FRONT BRAKE
REAR BRAKE
Kirk
The Porsche seal kits include replacement pistons that you don't really need so I would just order the dust boots & pressure seals from StopTech for $50USD/caliper. And if we could find a Brembo dealer that actually had a clue it would be even cheaper.
looks like I will have to order from stoptech as I am having no joy anywhere else
looking at that list above all the steel plates have different numbers! buggerI thought they were all the same they are all mixed up in a tub soaking
Originally Posted by KirkF
Now if we could just find a cheaper source for the springs and plates!
Porsche #993-352-959-01 Brembo #120468310
Porsche #993-352-959-00 Brembo #120468311
The dust boot part number is visible on the outside face of the boot. So the only problem now is finding the part numbers that correspond to the color splotches on the pressure seals.
$100 for the front 2 calipers from stoptech but with shipping and tax $153.46 for 8 tiny pieces of rubber
and I'll probably get hit for import tax and vat knowing my rip off government)
Hi, Sorry for delay i have piston seals for 36,40 & 30 mm pistons £1.90 each. The 28mm we cannot offer it is one i`m currently trying to source.
With regards to the dust covers we have found in the past this is almost impossible to do without the actual caliper.
The piston bore size does accurately pinpoint the dustcover required.
In most cases Brembo use a metal/Rubber hard dust cover, we can in some cases offer a rubber cover with retaining ring.
But the area to locate the ring varies on different models and without seeing the unit in question its not possible to discern if we have suitable units.
Regards
Regards
Well as per this discusson:
https://rennlist.com/forums/showthre...light=stoptech
It looks like stoptech is missing the 30mm/28mm kit.
Kirk
Kirk
Ian Thanks for that.
if it helps I have a full set of calipers sat in a drawer at work. do you think it would help them?
I was planning on getting them cleaned up and painted/powder coated and then replacing the seals etc.
after ive painted them i could remove seals and post them the old ones or depending on where they are drop em off a front and rear caliper
Ok more info you you UK guys.
looking on the stoptech website I tried 4 of the UK supliers of stoptech products listed.
2 numbers were dead
1 answered but had never heard of stopstek
then abby motorsport came through. but its not good.
email said
"located caliper repair kits,part ref 89-100-3640.
Do you require one or two kits,One kit to each caliper
Price for each kit £60.00 plus vat,Delivery aprox £7.50"
£148.50 including VAT and postage
is it April fools day?
For our american friends thats aprox $270.68 USD Talk about Rip off Britain!
will phone up that place Ian has been talking to today and see if I can arrange driving down there and dropping of some calipers.
2 numbers were dead
is it April fools day?For our american friends thats aprox $270.68 USD Talk about Rip off Britain!
Cheers Pesty, would be good if you could get the calipers over to BiggRed.
That Abby motorsport price works out more than getting them direct from Porsche - I think the OPC quoted me about £12.50+VAT per piston for seal and dustcover, and £15 per spring plate kit.
Ok just phoned a place called GPR distribution who are apparenly the people who import all brembo products to suppliers in the UK.
Phone number 01327 855 585
they have dust covers for 40mm and 36 at £10.80p +vat each
seal kits come in 8's of each size and are 46.61 +vat
so for £110.72 would be enough to do 4 front calipers. + dust seals
Perhaps Ian If Big red doesnt work out we may have to go halves.
