964 Forum 1989-1994
bad noise on start up
Old Apr 21, 2006 | 07:48 AM
bwoodry's Avatar
bwoodry
Default bad noise on start up
I have a nasty noise on start up and when the oil pressure comes up within a second it goes away.
After much consideration and some searching on previous posts I have determined it is either timing chain tensioners not having pressure which causes the rattling or a starter motor gear not pulling away from the flywheel.
Now considering that this only happens after the car sits overnight and never during the day of driving during restarts I feel it is the chain tensioners. Possibly the springs are weak on the tensioner of the cam chain and it allows the chains to rattle around until oil pressure moves the tensioners
Question,, is it difficult to replace the springs on the chain tensioner , can this be done with relative ease?
Any experience in this area ?
Bob
Old Apr 21, 2006 | 09:00 AM
Heirsh's Avatar
Heirsh
I don't know about the springs themselves, but the chain tensioners don't look too bad to replace. I was going to do it because I have a bit of chain slap if the car sits for 3-4 days without running, but I'm delaying it for now.
Old Apr 21, 2006 | 09:18 AM
dfinnegan's Avatar
dfinnegan
I believe that you need to put in a chain with a master-link if you don't break down the engine. At least that's what I've read about the pre-'89 911's.
Not that that's necessarily a bad thing, but probably not optimal.
Cheers,
Dave
Old Apr 21, 2006 | 12:12 PM
Heirsh's Avatar
Heirsh
I don't think you need to replace the chains when replacing tensioners? They push in from the outside of the chains so should be no problem?
Old Apr 21, 2006 | 12:26 PM
dfinnegan's Avatar
dfinnegan
Ah, chain tensioner . . . sorry.
Old Apr 21, 2006 | 12:59 PM
garrett376's Avatar
garrett376
Chain tensioners are accessed and removed by taking off the small cover - bottom side of the engine on the right, top side on the left. They just slide right out. I have not heard of these needing replacement... at least on this forum.
Old Apr 22, 2006 | 08:29 AM
bwoodry's Avatar
bwoodry
Perhaps a spring is bad or the oil is not getting to them fast enough. The other optionis the Start,, but it only happens on initial start up.. Any ohter ideas?
Tks
Bob
Old Apr 22, 2006 | 05:58 PM
bwoodry's Avatar
bwoodry
I pulled the spring tensioners and checked the oil jounals etc, , they seem fine, so what next?
Could a failing CAT Converter make this noise?
Bob
Old Apr 23, 2006 | 11:22 PM
bwoodry's Avatar
bwoodry
Would valves needing adjustment make this noise on start-up?
Bob
Old Apr 23, 2006 | 11:37 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
If your valves are loose and in need of an adjustment they will make the sewing machine noise all the time.
so what next?
I would go down to a local pharmacy and spend $5 for a stethoscope. They really help to pinpoint the source of weird noises. Another option is to record the sound into an .mp3 file and post it here.
Old Apr 24, 2006 | 08:15 AM
bwoodry's Avatar
bwoodry
Jason:
Thanks,, I have someone coming over to listen to the noise today.
Bob
Old May 21, 2006 | 08:09 PM
bwoodry's Avatar
bwoodry
Update:
New spring Tensioners and rails solved the problem.
Tks
Bob
Old May 21, 2006 | 09:28 PM
Heirsh's Avatar
Heirsh
Ah thks. I guess I need to spend the cpl hundred and do this as well. I just dont care for that awful sound
oh hey, do you still have your old ones? Could I buy them off of you?
Old May 21, 2006 | 09:51 PM
BaysideC4's Avatar
BaysideC4
I need to replace them too - Any advice on the installation and cost? Thanks
Old May 21, 2006 | 11:15 PM
JasonAndreas
Technical Guru
The hydraulic chain tensioners are oil pressurized springs so you don't necessarily have to replace them (I didn't). Instead you can take them out (they're held in place with two nuts) and clean them and (more importantly) at the base of the lower tensioners, remove the oil sludge.
