Mobil 1 Oil Filter
I've used them for the past three years and am very pleased with them. I can't compare them with the others you mentioned - don't have experience with them. The Mobil 1's just make sense to me - heavier casing and designed for the oil I use.
i had seen a thread a little while ago about these...seem to remember the consensus being that Mann, Mahle or Bosch were the way to go because of anti-drainback valves and flow rate issues with M1 filters...correct me where i am wrong, but that is what i remember reading...I've never tried the M1, always used Mann filters.
I've got to ask...if one is using any of the qaulity brand filters and doing regular oil changes, does the filter really play a large role in longevity?
I've been using the Wix brand filter as they are available locally, cost about the same as mail order and they are a known quality filter. I change the oil every 3000 miles. Can I really be missing out on something by not buying a different brand?
How does one tell which brand is best? While I agree that I do associate heft with quality, the weight of the Mobil 1 or K&N filter could simply be the mounting nut welded to the case and not due to the filter material itself being of substantiated quality.
http://people.msoe.edu/~yoderw/oilfi...lterstudy.html
Wix
"This could allow dirty oil to seep from the dirty side to the clean side of the filter, bypassing the element." ?
Wix
That is a good review of filters. One thing I observed is that the Wix filter is apparently one of the better filters, and other than what you mention, it would be very satisfactory.
Indycam, thanks for the link. Interesting to note. I'm not sure I feel that the amount of oil that could bypass the filter is of overall consequence however I'll keep in mind next time I buy filters.
I'm thinking of doing the same sort of filter comp for 964 filters . Anybody care to send me your old used filter so that I could do a sneek and peek ?
Mobil 1 m1-404 ? m1 -209 ?
Fram PH2842
Wix 51283
Purolator L30260
Mann + Hummel W 940/29
Mahle OC-54
Bosch 72158
K&N Performance Gold HP-4004
Amsoil Ea 51283
Pennzoil PH2842
Napa 1283
ACDelco PF2044
Beck/Arnley 0418041
Champ
Champion
Penske
Fram PH2842
Wix 51283
Purolator L30260
Mahle OC-54
Bosch 72158
Amsoil Ea 51283
Pennzoil PH2842
Napa 1283
ACDelco PF2044
Beck/Arnley 0418041
Champ
Champion
Penske
