Blower motor making NASTY sound
Originally Posted by Hambisa
If you install the by-pass pipe/tube, don't you also have to do some finagling with the temp sensor? I remember reading something about that in aprevious thread or one of the DIY sites.
I am also wondering if there is a "plug" for the female-end (engine bay-end) of that wiring harness since the blower motor won't be plugged in there anymore???
Garrett, you're definitely right about the weight. I made a comment about Pelican's "slight exaggeration" on the 993 boards because I posted this same problem here in hopes of more help. I weighed the entire blower motor assembly myself and it was 9 pounds on my scale. I guess you need to recalibrate your scale, huh?
JasonAndreas, I ordered the Carbon Fiber bypass tube that is pictured above, but it won't be here until next week so I planned on putting the blower assembly on (minus the motor itself) until then; just as you suggested. Thanks for the confirmation that it will be a preview of what I will get with the bypass.
Hopefully it will work out well. I think it might. Looks cool and is MUCH more simple, too! I love simplicity...
Thanks everyone. I'll tell you all how it works out next week.
![jumper](https://rennlist.com/forums/graemlins/jumper.gif)
-Harry
Originally Posted by Euromagination
... I guess you need to recalibrate your scale, huh? jk...
Originally Posted by garrett376
To do it right you need to give the blower motor, AND temp sensor some resistance to keep the electronics happy. I did a post on this somewhere... ![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
That said, I just went on a drive without the blower motor installed in the casing. It seemed there was ZERO flow coming from the car except for when I was going faster than 30 mph. ??? I can understand a reduction, but there is now zero flow when there are two other blower motors up front... ???
Is this because i dont have the motor hooked up? The broken circuit there is making it so none of the blowers work?
Thnx. Never a dull moment for me and any of my cars
-Harry
Just FYI...
The resistors in the thread that garrett made and referred to above have the following part numbers:
***15W 50 ohm 1% ----> Mouser P/N: 284-HS15-50F ----> (No Mfg. P/N listed)----> Arcol 15W aluminum housed wirewound resistor
***2W 18K ohm ----> Mouser P/N: 262-18K ----> Mfg. P/N: MOR02WJ0183B00 ----> Xicon Std. Size 2W metal oxide resistor
Mouser Electronics----> http://www.mouser.com
And thanks again garrett...![Cheers](https://rennlist.com/forums/images/smilies/beerchug.gif)
-Harry
-Harry
Originally Posted by dfinnegan
Doesn't the blower run to dump heat off the engine into the rear wheel wells when the engine gets really hot?
Is it okay to take away this cooling funcationality?
i plan on updating this thread with a summary of what i think about the bypass in a couple of weeks.
here's another great link:
http://tech.rennlist.com/911/pdf/add...ipeInstall.pdf
And an FAQ list is on this page (halfway down, right before the pictures):
http://www.rennlight.com/rstube/index.html
Technical Guru
Don't bother with a used motor off E-Bay, it's a crap shoot if it will be in better shape than what you've got. Vertex (I believe they are a rennlist sponsor) sells the bare motor for around $100. It's not hard to install. I tried two used blowers off E-Bay before finding out about this. If there are any questions about swapping the motors, let me know. There was a post detailing the DIY procedure, but I can't seem to find it now.......
(I just checked, and they show it as not currently available...... it's Vertex SKU # 0130111145, if you feel like calling them)
