Interior Retrim Phase 2 - The Strip!!
So was out at snooker this morning and came back home at lunch time quite energetic, and decided today was "strip the 911" day!! My fingers are a mess and there were sometimes when the air was blue, however man-over-motor triumphed again. I would like to say a big thanks to Jamie aka "ttAmerica RoadsterUSA" from rennlist for the help on top dashboard removal, his article was spot on, however I did get a little confused at one point and took out the clock to get at the centre of my dash nut and bolt only to remember it would be my other end guage as his is LHD and mines is RHD!! All in all not a bad day actually!!
Originally Posted by raymond-turner
Looking forward to this, I'ts my next project, don't skimp on the pictures. Cheers
I've got lots more but only just applied for membership so reached post limit on pics......I'm planning on doing a pdf document with all the updates.....
feel quite proud now, I know my car so much better.....Bailies Upholsteries just round the corner is doing the trim, so it's all going to him now, and the fact that I've taken it all out should mean it won't costs that much now about 500 quid probably, however there is a problem with the roof lining and the pillars just behind the front seats and that it is grey so need to order a new black roof lining and get him to do the pillars in place, and then get it fitted which to be honest I'm not really looking forward to, I might seek some professional help with that. In fairness the centre console and dash was the worst but with some help from the net, it was done easily after me for a bit wondering what I was doing wrong.
The carpet is staying in place, however I'm gonna try and get the rear seat delete kit either made or ordered via the net to replace the rear seats - see pic attached. It's a bit like a low level parcel shelf, and is similar to the standard RS Cup & America cars rears. The UK RS's are just carpet but I'm not doing that, I'm retrimming my original panels unlike an RS. I'm struggling to get the seats out as it needs a very big flat blade screw driver, and my trusty toolkit is short of one!!
Here are the parts, all in order.......might run a book on what will be left at the end!! In fairness the rear seatbelts are not going back in anyway.
Question is, do I use 6pt harnesses or just standard seatbelts?
Originally Posted by inkyboy911
Puma how did you get your rear seats out?
Jamie
964russ (12-05-2021)
I knew it was money, but not how much.
Quid:
A small, circular item similar to a dollar; for example, sand dollars
British slang for one pound sterling (£), originally referring to the pound note (plural is quid, not quids, despite the expression "quids in", referring to a financially positive end to a transaction or venture). The Irish pound and the Australian pound were also referred to by this name. Can also refer to Euro currency in Ireland, although the term yo-yo has also been coined for the euro.
Kirk <- learned something new.
Now do you wanna know what a loonie is?
Quid:
We have been using $ since 1966 buit still the expression "earn a quid" is regulalry used (ie make some some money, get a job etc etc.).
Q where do yu start first, re do the interior or make sure the motor, suspension, brakes etc are hummong and there is a good exterior?
Oh the problems and decisions?
I don't think it matters where you start, the only rule I follow is that when I start a job I complete it before getting tangled up in another area. Otherwise you are liable to get 20 unfinished jobs started and the whole process seems unconquerable.
Right now I am working on on my motor rebuild / clutch. Its expensiv enough to keep me away from other problems!
Kirk
Kirk
