Where does the rear reflector vent hose...
attach to the inside of the engine compartment? Not the blower pipe near the distributer vent, the reflector side. Mine is loose and I am not sure where to plug it in.....
Thanks,
Scott
Thanks,
Scott
I've had that piece and the corners off numerous times so i think I know this system decently, but I'm having trouble following your question.
The hose comes from that plastic piece with the dist vent hose. It goes to a nipple somewhat left of center (if my memory serves me right) and near the edge of the compartment, fender side. On the other side of this nipple the hose goes into the center reflector. I think its a double sided nipple and thus a new piece of hose on each side of it. One for the reflector and one for its supply of air. You should be able to see the nipple if you stick your head intot he compartment a bit and look back down and sort-of under the edge of the latching area.
I typically write poor technical directions, I apologize in advance. Hope some of this is useful.
I'll have a look around. I'll take off the reflector too as I did not know that there was a hose on the other side of the latch panel.
Two distributor vent hoses? I guess one is good, two should be better!
Scott
Scott
Super Duper Moderator
Originally Posted by stevepaa
There was none initially. Then they came out with one. I added the second.
Marc
Registered User
you can see on that picture the vent hose going to the rear reflector right at the bottom of the picture .
its the pipe with an offset , rather than the 2 with curves .
