964 Forum 1989-1994
pulling
Old Jan 3, 2006 | 09:27 AM
citychap26's Avatar
citychap26
Default pulling
Hi Guys,
I'm going to drop the 964 to Camtune in the next week to get the clutch sorted.
However I've noticed a couple of other issues.... The car appears to be pulling to the left when I accelerate and then to the right when I step off the gas (sorry being American )
Also when I shut either door there is a metallic bang (well noise) which comes from the engine bay.
Are these related?
Cheers
Sunil
PS Happy New Year all!!
Old Jan 3, 2006 | 09:33 AM
Greg_L's Avatar
Greg_L
Hi Sunil,
How are your front tyres looking? is the wear even? Have you done anything recently that could have knocked the tracking/camber out?
Old Jan 3, 2006 | 09:38 AM
citychap26's Avatar
citychap26
Hi Greg,
I've not check on the condition of the tyres yet... I don't remember hitting any speed bumps too hard. I hope it is something as simple as tracking.
I was thinking of having lowering springs fitted so might as well have the 4 wheel alignment done then.
Old Jan 3, 2006 | 09:46 AM
Seight's Avatar
Seight
Hi Sunil,
not too sure about the car pulling but the metallic noise from the engine bay is nothing to worry about. There was a mail about this recently, something to do with when the heater is on then a flap in the blower/heater system which is in use opens and closes as the doors shut making the small metallic flap noise in the engine the bay. In this cold weather, with the heaters on people seem to be noticing this more than in the summer......
Cheers
Alex
Old Jan 3, 2006 | 09:50 AM
citychap26's Avatar
citychap26
Hi Alex,
Cheers for the mail... Glad that the metallic sound is not going to cause me grief. I'm a little p*ssed about the car pulling though.
I guess I'll keep you boys posted on the clutch and pulling situation.
Cheers
Sunil
Old Jan 3, 2006 | 10:07 AM
Rocket Rob's Avatar
Rocket Rob
IHI KING!
Sunil,
I would check the tire pressures of all 4 tires (tyres). A low tire can cause the car to pul to one side.
Old Jan 3, 2006 | 10:36 AM
Jeremy Pinsly's Avatar
Jeremy Pinsly
I hear that noise from the engine bay on my car when closing doors also. Never knew what it was. I heard it on Jimq's car too.
Old Jan 3, 2006 | 11:27 AM
citychap26's Avatar
citychap26
Hi,
Some good points, what should be the correct tire pressures for 17's ?
Cheers
Sunil
Old Jan 3, 2006 | 11:30 AM
Jeremy Pinsly
34 front, 36 rear (in psi)
Old Jan 3, 2006 | 11:49 AM
Chris M.'s Avatar
Chris M.
34 front, 36 rear
Really? Mine says 44 rear 36 front on the sticker in the engine bay. Was that only for the D90s? It's had 17" Cup IIs for a long time.
Yes, that ping pong ball sound when closing the door is strange isn't it.
c
Old Jan 3, 2006 | 12:01 PM
Jeremy Pinsly
16 inch wheels will require a higher pressure than 17 inch wheels.
That sticker you see is for the stock D90s (16")
Old Jan 3, 2006 | 01:12 PM
williamreinecke's Avatar
williamreinecke
I had the same "pulling" problem and it was the tires. Try switching them side to side, and the problem with switch sides with the tires. New tires cleared it up.
Old Jan 3, 2006 | 01:13 PM
williamreinecke
Here is a link:
https://rennlist.com/forums/showthre...ighlight=darts
Old Jan 3, 2006 | 05:16 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Check
HERE.
Old Jan 4, 2006 | 03:12 PM
citychap26's Avatar
citychap26
Hi Chaps,
It was the tyre pressure! I had 14 psi in the nearside read and 24 on the offside! They're both sitting in at 36 and the car is flying, well kinda... Booking in next week for the clutch!
Cheers
Sunil
