RS or cup washer bottle and a battery cutoff
I’ve been searching the archives with no luck…could be I’m slow
. I thought I saw a pic a while back of an install of an RS or cup washer bottle and battery cutoff. Anyone know where I can find the pic? Thanks in advance.
Guru
Rennlist Small
Business Sponsor
Rennlist Small
Business Sponsor
I particularly like the dual m/c reservoirs... which indicates separate circuits for adjustable brake balance--cool stuff!!!
Jim: it's so typical. Just because I promised you the numbers I can't find one of them on my old invioces. I can see the parts in teh PET5 program but the part numbers doesn't show. But your OPC should find the, just point on his screen and show him what part you want. This is what I could find in my papers:
Bracket för battery cut-out 964.450.173.300 GRV
Bracket for washer bottle ???
bottle 964.528.019.02
Cap for bottle 911.628.077.00
the kill switch itself is a regular switch from OMP. There's instructions in the package but if you're not really sure of what you're doing leave this to a workshop. To do it properly one connection is going through the DME-relay which easily could be a mess.
I'll try to attach a pic from the PET5 showing the washer bracket.
Thanks Thomas. Did some surfing and found 2 very interesting cars for sale. Very nice photos for reference, if they are the real deal.
http://www.rpmsportscars.com/door25a.htm
C4 light weight
http://www.rpmsportscars.com/door39a.htm
Cup car
C4 light weight
Cup car
The bracket for the water bottle is part number 964.501.261.00.
Note some earlier 964 chassis have this bracket installed already as it was part of the intensive windshield cleaning option. The bracket may be there whether or not you have the option installed.
I covered the installation of the kill switch in this thread if that's what you're looking for:
https://rennlist.com/forums/964-forum/189368-mystery-solved-964-kill-switch-done-the-right-way.html
One nice touch when you do the installation is to go to VW for the female of the plug Porsche uses at the fender mounted water bottle. This way you can make up a harness with male and female plugs to connect to the new motor's location without cutting the original harness.
If you want the VW part number on plug let me know and I will dig around for it.
When I deleted the big bottle I cut the hose and electrical contacts so I could re-use the part with the new bottle. I the re-routed everthying after looking on a Euro RS. It's now impossible to see that new bottle wasn't installed 14 years ago!
From my OPC I even found the right rubber plugs to use where the hose and cable goes through the metal. I don't have the part number for those though. I brought wan to my OPC and after some time we found similiar ones.
