Who has replaced window seals on a cabrio?
IHI KING!
hi Rob, thanks for your reply. I believe that thoroughly cleaning the surface before applying the silicone is a must, right ?
Did you remove only the old gasket ? or you did remove the locking pieces of the cab roof ? (you know .. the metallic pieces were the roof goes and lock itself)
I believe the PERMATEX BLACK SILICONE ADHESIVE SEALANT is a similar product. I'm asking this because the 3M one doesn't seem to be easily accessible here in europe. (belgium at least).
What do you think ?
permatex black
Thanks for the help !!
What do you think ?
permatex black
As for the Permatex, the 3M weather strip adhesive is a contact cement. I'm sure many types of glue can be used. Let us know how it works out.
