Possible new wheels
hi,
maybe changing the d90's for new wheels........will these fit and what size of tyres are correct
cup 1
front 7.5 x 17 et 15
rears 9 x 17 et 23
will these fit...if not what should i be looking for regarding size and et values
cheers steve
cup 1
rears 9 x 17 et 23
cheers steve
Agreed, those low offsets must be replica wheels for older 911s/944s. 964s and late 944/968s use the higher offset wheels. Here are the factory specs:
7x17 et 55 (965 362 124 00) for C2/C4 front
7.5x17 et 65 (965 362 124 05) for 968 front
8x17 et 52 (965 362 126 00) for C2/C4 rear
9x17 et 55 (965 362 128 00) for C2 TURBO, 968 rear
You can do some mixing and matching with the applications, i.e. using 8s and 9s on a C2/C4.
I have seen some of the replica cup wheels that have a 47mm offset on the 9" wheels. These acutally look pretty good on the rear of 964s and 944s, because they fill up the rear wheel well nicely. But the 15 and 23mm offsets you mentioned will not fit on your 964.
Super Duper Moderator
That is what I have (except 8.5 rears - Boxster twists). I needed a 5 mm spacer front otherwise they'd rub on full turn - otherwise perfect.
Marc
Marc
Originally Posted by cockyapple
hello,
would these sizes be suitable
F- 7 x 17 et 55
R- 9 x 17 et 55
F- 7 x 17 et 55
R- 9 x 17 et 55
