964 Forum 1989-1994
964 Rs wheels
Old May 14, 2002 | 04:52 AM
si's Avatar
si
Post 964 Rs wheels
please could someone tell me how to recognise genuine 17inch 964 magnesium cups, thanks Si
Old May 14, 2002 | 05:01 AM
Adrian's Avatar
Adrian
Lead Rennlist
Technical Advisor
Lifetime Member
Talking
Dear Si,
You need to check the part number. This is the only reliable way. The part number is on the inside of the wheel. I do not have the actual number handy right now but just post it and we can find if for you in short order.
Ciao,
Adrian
911C4
Old May 14, 2002 | 10:42 AM
Bill Gregory's Avatar
Bill Gregory
Technical Specialist
Lifetime Member
Post
Si,
Per information from an owner of the magnesium wheels, "An indicator is that the magnesium wheels say "magnesium" in the casting between 2 spokes, were made in Germany by Sett, as is probably your spare tire wheel. If you look at your spare you will see the Sett emblem cast into the wheel, the Mags also have the same thing cast into another space between spokes." As Adrian mentioned a part number would help to identify the wheels.
Old May 15, 2002 | 07:21 AM
George Stevens's Avatar
George Stevens
Post
I have owned two sets of genuine RS mags off euro cars.
Where the rims joint the spokes they have stamped "SM made in italy" & "Magnesium" also stamped on the front face is the rim width and offset. 55 offset front and rear 7.5J front 9J rear
The other sure sign is a scratched face where they have been dropped and paint flaking off!!!!
They are so valuable and rare now, personally I wouldn't use them (keep them safely stored), 17" 993 Cups are a good alternative (correct 55 offset)
Old May 15, 2002 | 07:35 AM
C2RS's Avatar
C2RS
Post
Hi George
Have you got any idea how much the 993 cup rims are? I have got a 964 RS with immaculate mag rims on, and would prefer to keep them that way!
Old May 15, 2002 | 09:42 AM
Christer's Avatar
Christer
Post
[quote]Originally posted by C2RS:
<strong>Hi George
Have you got any idea how much the 993 cup rims are? I have got a 964 RS with immaculate mag rims on, and would prefer to keep them that way! </strong><hr></blockquote>
C2RS, I have some 993 Cup 'Twist'wheels, offset 55 front and rear 7x9J. These are OEM and cost £450+VAT (they came off a Boxter S originally but were basically new). I think I purchased them at <a href="http://www.porscheshop.co.uk" target="_blank">www.porscheshop.co.uk</a>
Christer
Old May 15, 2002 | 11:47 AM
C2RS's Avatar
C2RS
Post
Thanks Christer!
Old May 16, 2002 | 04:39 AM
si's Avatar
si
Post
George, like your car!! what started this was looking in the current issue of GT magazine, theres a feature on a 964RS with a close up of one the wheels, a previous issue had another close up of a 964RS wheel on a different car, basically the wheels are different and was wondering which was the genuine wheel... (I know sounds very sad), If youve got the mag, take a look, Thanks
Si
`91 951s
`82 Golf GTI
(soon to be joined by ur-Quattro).
Old May 16, 2002 | 05:37 AM
George Stevens
Post
C2RS
If you are lucky you should be able to get a set of 17" 993 cups in the UK for about £500 with reasonable tyres, and I would really recommend fitting them, plus when you sell the car you will always get your money back, I have sold mine with two sets of wheels.
Si
To be really sad I will try and take some close up photo's this weekend of a mag cup wheel (with all the identifying features), there was only one type fitted to the 964RS and that was the cup 1 style but from the posts above perhaps there was more than one supplier (Adrian can you clarify this?)
Old May 16, 2002 | 09:15 AM
Bill Gregory
Lifetime Member
Post
[quote]
<strong>made in Germany by Sett, as is probably your spare tire wheel. If you look at your spare you will see the Sett emblem cast into the wheel</strong><hr></blockquote>
Received updated information on RS magnesium markings, that:
1. By the valve stem "9JX17 (Valve stem between) ET55"
2. If valve stem is at 12:00 then in the interval between spokes at 5:00 it
says: "Made by SM"
3 In the 7:00 space it says: "magnesium"
Old May 26, 2002 | 04:20 PM
Rob/RSA's Avatar
Rob/RSA
Post
there are two types of magnesium cup wheels, I have both sets. The cup I, and an extra set of the cup II style, often found on 993's if anyone is intrested. The part #s for the type I is...
8x17 965.362.126.01
9.5x17 965.362.128.05
if you need the type II #s let me know
Old May 26, 2002 | 05:45 PM
Bill Gregory
Lifetime Member
Post
[quote]<strong>there are two types of magnesium cup wheels, I have both sets. The part #s for the type I is...
8x17 965.362.126.01
Rob,
How do you know those part numbers are magnesium wheels? In the Porsche parts catalog, 965.362.126.01 shows as an aluminum alloy 17" wheel used with option M403 (cast 17" wheel) and on Turbo look 964's. 965.362.128.05 shows as aluminum alloy on Turbo look and Turbo's.
Old May 27, 2002 | 06:07 AM
George Stevens
Post
I think Bill is right
On the euro 964 RS the only cast magnesium rims I have ever seen have been the cup 1 style which were of a similar design to the 3.3 964 Turbo.
Bill is absolutley correct as he states above, these wheels are easy to identify
[quote] 1. By the valve stem "9JX17 (Valve stem between) ET55"
says: "Made by SM"
3 In the 7:00 space it says: "magnesium" <hr></blockquote>
I have never seen 993 cup 2 style 17" cast mag wheels, I believe that all 993 RS cars were supplied standard with 18" split rim Speedline magnesium wheels.
I understand that the only other cast mag wheel used on the 964 was the design 90 style used on the Carrera 4RS which was produced in very limited numbers.
Old May 27, 2002 | 01:38 PM
Rob/RSA's Avatar
Rob/RSA
Post
I bought both sets from a 964 racer, who said he bought them from the factory, on a trip to Germany. He claimed both sets were used on the 964 cup cars. Are these the same as used on RS street cars, now I'm not sure. I have seen early photos of 964 cup races in action, with cup II wheels on them. The 993 RS did have the speedlines. My guess is that the factory has used a number of wheels during the cup series. I think I have the genuine wheels because, because both sets are so much wider than the stock wheels. Here are some additional markings.
Cup I GK-ALSiMg0.4wa...9.5jx17AH-ET68...SL594... made in Italy
GKALSiMgWA... 8Jx17 AH-ET52...SM
Old May 27, 2002 | 01:51 PM
Rob/RSA's Avatar
Rob/RSA
Post
Part II.. The Cup II wheels part numbers are
993.3622.126.01
6KALSi7 MgWA.... 8Jx17-3770 SM
993.362.128.00
6K-alSi7mg0.4 9Jx17 SL Italy
On both sets, spacers are required to mount them.
Rob
