964 Forum 1989-1994
Slick 50 (for engine & transmission)
Old 08-04-2002 | 07:11 PM
Marcel Van Zweeden's Avatar
Marcel Van Zweeden
2nd Gear
Question Slick 50 (for engine & transmission)
Has anyone ever used Slick 50 in their engine and/or transmission before?
Their are so many lubrucants on the market, however from my previous experience in another car: after adding Slick 50, the runs at a bit higher idle, which makes it run more smoother and quiet.
Anybody any experience in this area?
Old 08-04-2002 | 08:15 PM
Flying Finn's Avatar
Flying Finn
King of Cool
Post
Friendly advice:
Don't use it. Use Mobil for both (different oil, of course), it's a big oil company who does a lot more R&D than any of these 'oil add on companies' so I'm sure if there is something that'll make you engine runs better etc. it's in their oils already.
Old 08-04-2002 | 09:08 PM
Marc '91 C2 Coupe's Avatar
Marc '91 C2 Coupe
Post
Hi Marcel,
I tried it in an old Plymouth Turbo (Mitsubishi motor, I think) about 10 years ago, and it worked quite well. There was a noticeable improvement in throttle response, I guess because there was less internal friction. Only problem was that it worked too well. The engine revved so freely, that it caused the cam belt/chain to jump a cog! Cost me a few hundred dollars to fix...
Would I use it in my 964? I don't see any need or reason to. Plus, if Porsche hasn't approved it, I'd stay well clear of it.
Cheers,
Marc
<img src="graemlins/beerchug.gif" border="0" alt="[cheers]" />
Old 08-04-2002 | 09:50 PM
christian's Avatar
christian
Talking
Don/t buy any of this stuff! It will actually ruin your engine. And I don't believe that an engine will rev more free and a belt will jump, that's really funny! The only thing you can use is something called Lucas heavy duty oil stabilizer. It will keep your mobile 1 oil in places where a cold start is causing a lot of wear.
Old 08-05-2002 | 11:54 AM
GaryN's Avatar
GaryN
Thumbs down
Hi Marcel,
I've been told by 2 separate Porsche specialist here in the UK to steer well clear of those add in's. I'll rather take their advice and hopefully save some servicing costs... <img src="graemlins/crying.gif" border="0" alt="[crying]" />
Cheers
Gary '91C2 (with Aircon "still" working!! )
Old 08-05-2002 | 01:27 PM
Geoffrey's Avatar
Geoffrey
Post
If slick 50 was so great, car manufactures would be using it from the factory. I would wager, they know more about this stuff than we do.
Old 08-05-2002 | 05:17 PM
Arjan B.'s Avatar
Arjan B.
Thumbs down
Marcel,
As a real 'Dutchman' you should think clear.
Did you ever see a Porsche damaged when good oil was used???
The oils today are mjust fine, you don't need that stuff, let them sell that to Mr. Johnson with his 1992 Ford Tempo ..............
Use good Porsche approved oil, nothing will happen.
Arjan
964 C2 1992 Black
Using Mobil 1 , 0W40 ......great! <img src="graemlins/nono.gif" border="0" alt="[nono]" />
Old 08-05-2002 | 08:18 PM
Marcel Van Zweeden
2nd Gear
Post
Hi All,
Thx for the feeback, I got the message, and will not consider any lubricants
Marcel
Old 08-06-2002 | 04:41 AM
pig4bill's Avatar
pig4bill
Post
Long time ago my friend put it in his 2 year-old Chevette. A month later it blew up. Literally blasted a hole through the side of the block. He reached in and pulled a horseshoe shaped rod out of the hole. Maybe coincidence, maybe not.
Quick Reply: Slick 50 (for engine & transmission)
