964 Forum 1989-1994
Getting ready for Driver's Education
Old Jan 20, 2002 | 09:05 PM
sullivs's Avatar
sullivs
Post Getting ready for Driver's Education
I am readying my new '93 for Driver's Ed. And I noticed when I remove the floor mats, the thick black rubber insulation is rather well attached to the floor. I know we want to remove loose items, like the floor mats. But it appears that having the rubber insulation in place would not be a good situation. What do other 964 owners do in this case?
Thanks,
Steve
Old Jan 20, 2002 | 10:02 PM
Kevin's Avatar
Kevin
Post
Steve;
Actually there is foam (almost 2" thick) attached to the black asphalt material. I use a heat gun and plastic knife. It is a slow process because the carpet is glued to it also. If you do not remove the pads, your feet will poke holes right through the pad.
Old Jan 20, 2002 | 10:07 PM
Bill Gregory's Avatar
Bill Gregory
Technical Specialist
Lifetime Member
Post
You can do what some racers do, which is craft a thin, shaped, wooden floorboard to go over floor and thus the rubber insulation. I'd anchor it in place with at least one bolt and spacer, or otherwise secure it.
Old Jan 21, 2002 | 01:12 AM
Jeff Curtis's Avatar
Jeff Curtis
Post
A popular mod to the floorboard is a sheet of aluminum...this works fairly well, again, just a few spacers and screws. It can be installed right under your carpet and you would never know it was there until you pull your mats/carpet out.
I have a picture of this setup, will try and find it and post it...it was on a friend's 964.
Old Jan 21, 2002 | 02:39 PM
sullivs's Avatar
sullivs
Smile
Thanks for the ideas. It sounds like the best way to go is leave the rubber there and cover it with wood or aluminum. Thanks again.
Steve
