Carrera II major service
I bought my 1991 Carrera II a little over a year ago, and it now has a little over 100K. on the speedo. It had just had it's major service, when I bought it. I have put 13,000 miles since then, so it is ready for another service. I plan to do all except the valve adjustment. I know the air and fuel filters need to be changed, as does with the oil and filter. I plan to change to Mobil One at this time. What else needs to be done, checked, etc?
I appreciate any advice.
Bill Seifert
Bill Seifert
Bill;
Check and see your condition of your cap and rotors, additionally I would check to see when you replaced your O2 sensor, and maybe start saving for a cylinder temp sensor. Check to see how your power steering belt is. And of course your distributor belt. Good luck.
Bill,
According to the Porsche Warranty & Maintenance manual, here is what is required every 15000 miles/24000 km. (By the way, I have a 1990 car, but I'm pretty sure the maintenance schedule is the same as for a '91.)
Change engine oil & filter.
Check valve clearance.
Diagnosis system: read out fault memory.
Visual inspection for leaks: oils & fluids.
Toothed belt for power steering pump: check condition.
Crankcase ventilation: check tightness of hose connections.
Fuel system: visual inspection for leaks, damages, clearance and tightness of line connections.
Intake air: check hoses, lines and connections for tightness.
Parking brake: check free travel of parking brake lever.
Brake pedal: check play of brake pedal. Brake hoses and lines: visual inspection for leaks, damage and corrosion. Check brake fluid level.
Brake system: visual inspecitoin of brake pads and discs to check for wear.
Clutch: check play or final position of clutch pedal.
Hydraulic clutch actuator: visual inspection for leaks.
Steering rack: check screw connections for tightness. Visual inspection of the bellows for damage. Tie rods: check play, tightness and dust caps.
Power-assisted steering: visual inspection for leaks, check fluid level.
Ball joints: visual inspection of dust caps for damage, Wishbone: check screw connections for tightness.
Manual transmission/axle drives: check oil level.
Automatic transmission: check fluid level.
Drive shafts: visual inspection of sleeves for leaks & damage.
Exhaust system: visual inspection for leaks and damage, check screw connections for tightness & attachment.
Tires: check condition and correct tire pressure.
Door stop: check operation and lubricate.
Door hinges: lubricate.
Check door, engine hood locks and safety hooks on front hood for tightness & operation.
Seals for doors, hood and roof: remove abraded rubber, apply suitable lubricant.
Safety belt: check operation and condition.
Check operation of vehicle lights. All headlights: check setting Horn: check operation.
Throttle linkage: check for smooth movement and full throttle opening.
Resonanz flap: check for smooth movement.
Check active cleaning system and fluid level.
Windshield washer, headlight washer: check operation, fluid level and nozzle settings, regard antifreeze content (editor's note: I'm assuming of the windshield/headlight washer solution) for the winter season.
Battery: check fluid level.
Check operation of all electrical control equipment and options.
Heater, ventilation, and air conditioner blower: check operation.
During road test or dyno test:
Brake pedal, parking brake, brake power assist unit, clutch, automatic speed control, steering, heating, air conditioner and instruments: check operation
Kick down: check operation.
Drive train, longitudinal- and lateral limited slip differential: check for noises & operation
Hope this helps!
-- Melissa
Hope this helps!
-- Melissa
OK, I know someone's going to ask, so I'll go ahead & list the 30000 mile/48000km service items while I have the list handy:
(everything in the 15000 mile list and...)
V-belt & polyrib belt: check condition & tension
Replace spark plugs (at least every two years)
Air filter: replace filter element
Automatic transmission: change ATF, clean ATF strainer or change filter resp.
Additionally required every 60000 miles/96000km
Manual transmission and axle drives: change oil
Automatic transmission: change oil in differential
Replace fuel filter
Required Every 2 years
Brake system: change brake fluid
Required after 4, 8, 10 and then every 2 years
Air bag system: check as per maintenance procedure.
Again, this is from my Porsche Warranty & Maintenance manual, which is for my 1990 car.
-- Melissa
Replace fuel filter
-- Melissa
