OBC display "backlight"
Driving on the highway suddenly the OBC display went almost invisible, but is still working. Some days later it worked fine again for awhile (letters in orange color), but then it went off again.
Is there a dashlight behind the LED?
Thanks for any help.
Originally Posted by jenskleis
Hi Frolich,
No need to worry. The OBC is backlit by two bulbs. They are easy to change, but you need to remove the steering wheel to get the rev counter out.
Take care,
Take care,
link for instructions on gauge removal.
I need the answer to this question too! Thanks! Anyone?!?
Originally Posted by GabiOsz
What type of bulbs are needed for this repair? This is a life saver as the replacement OBC and Gauge (which porsche recommends to rectify the problem) costs £600!
IIRC, it's the Sylvania 2721. Available from your local autoparts store. (i.e. Pepboys, Autozone, ....) The base of the 2721 is different from the OEM but will work with a little bit of creativity. When you compare the 2 bulbs and look at the base you'll know what I mean.
Originally Posted by fbfisher
Thanks, do you happen to know if one or two are needed for a 993?
You can get the bulbs with the proper bases from most German auto supply stores. VW/Audi, Mercedes, BMW, Porsche, etc. all use VDO gauges so a 10-pack of 0.9w bulbs (964.641.920.00) made by Jahn is around $5USD.
