964 Forum 1989-1994
Brake Judder
Old Mar 27, 2002 | 03:50 PM
apw964's Avatar
apw964
Post Brake Judder
Folks,
I recently got new brake rotors (discs) and pads all around on my 1990 c4. After about 2 thousand miles the brakes judder when braking at any speed.
Bearing in mind that the rotors and pads are new, and when they were initially installed I had no problems has anyone got any ideas ?
Could it be swollon brake lines causing the fluid pressure to change ? or is it more likely that i have warped rotors ?
Any suggestions would help, maybe someone could give me a sequence of things to check ?
Thanks in Advance;
Andy
Old Mar 27, 2002 | 06:44 PM
Kevin's Avatar
Kevin
Post
At first glance it kind of sounds like your warped your rotors. Did you blead your system after the install of new components? What pads did you install? Did you properly break in your new pads and rotors? All these things should have been done.
