964 Forum 1989-1994
Defrost button
Old May 19, 2005 | 09:28 PM
mxbanker's Avatar
mxbanker
Default Defrost button
Talked to my shop and they said you cant get these buttons(defrost and recirculating air ****/button) from porsche with out buying the whole dash unit, any ideas?
Old May 19, 2005 | 09:33 PM
Smokin's Avatar
Smokin
Ebay... They have a wealth of parts... Or anything for that matter. No matter what you want... If you look on ebay over a 2-3 month period... It will show up for sale.
Old May 19, 2005 | 09:40 PM
mxbanker's Avatar
mxbanker
Thanks smokin fitty! I look on ebay frequently and have had really good luck with purchases. Recently picked up original brochure for my c4- preety cool stuff on there
Old May 19, 2005 | 11:57 PM
JasonAndreas's Avatar
JasonAndreas
Technical Guru
Are you looking to replace the buttons because the icons on the front have worn off or because they don't work? The buttons/switches are available from any Porsche dealership, the part numbers are:
944-653-921-00
944-653-922-00
944-653-923-00
944-653-924-00
Old May 20, 2005 | 12:45 AM
mxbanker's Avatar
mxbanker
Talking
Wow, thanks.
Old May 20, 2005 | 08:31 AM
jimq's Avatar
jimq
Burgled
Darn dealer told me you couldnt buy the buttons. Said I needed to buy the whole unit. Think I will go back over and show them the numbers. We are talking about the 2 little square buttons on the right side?
Old May 20, 2005 | 04:15 PM
mxbanker's Avatar
mxbanker
Yes the 2 Little buttons. My dealer said the same even with part numbers-unavailable. This is the same unit in the 944 per I think adrians book so im going to check salvage yards for 944 buttons(should be less premium i think for 944 vs 911 maybe maybe not)
Old May 20, 2005 | 04:20 PM
JJJMCD's Avatar
JJJMCD
Just to clarify - you cannot buy just the plastic "cap" on each button (which you can pry off) - you need to buy the whole "switch", which is the actual switch mechanism.
My plastic caps were worn down, but the switch mechanisms worked fine, so I inquired about buying just the plastic caps - no luck, Porsche only sells the entire switch mechanisms. So, I bought all of the switch mechanisms (there were two - defog and recirculate was one switch mechanism and a/c was another switch mechanism - I think they were around $25 each).
Old May 20, 2005 | 04:58 PM
JasonAndreas
Technical Guru
Are the parts NLA, Factory Backorder or none in the USA/CAN? Did your dealer check the inventory of other dealers in the USA?
Old Jan 31, 2013 | 04:00 PM
darth_vader's Avatar
darth_vader
i know, i know - bringing the thread back from the dead, but looking at this :
http://www.autoatlanta.com/porsche-p...-88/813-30.php
the above part numbers are referring to a single tip switch - not two separate switches.
as it is depicted here :
any chance someone has figured out where to get just the two switches ?
Old Feb 1, 2013 | 02:20 PM
JasonAndreas
Technical Guru
M573 - WITH AIR CONDITIONING
(RIGHT SWITCH)
944.653.923.00
944.653.921.00 (LHD) (M573)
(LEFT SWITCH)
944.653.924.00
944.653.922.00 (M573)
964.653.921.00 (RHD) (M573) -
