Off the top of my head, I can confirm that the RS America had 7 and 8 wheel widths. I believe they are the same wheels as the 91-92 Turbo.
So, yes, original wheels do come in those widths. Ask the seller to provide the Porsche Part Numbers which are stamped on the inside of the wheels. They should read 964.---.---.---. something to that affect.
The rims are standard issue in silver painted finish.
All will fit on a 964.
Extreme care should be taken to verify that the RR wheel and tire clears the oil line in the wheel well. This tube is slightly flattened from the factory.
One last tip. You can get the offset information off the FRONT of the wheels. Next to the valve stem you will find two numbers: one is the wheel width and the other is the offset. The offset numbers should be 55 (mm) for Factory wheels. 70mm offsets for rear wheels are 993 wheels which will not work on the 964, so pay extra attention to this detail.
hallo
In Europe the 7+8x 17 was av. as Option from the Factory from up 1992 on all 964 ,the 9 inch wheel was only av. on the 965 Turbo and 964 Turbolook .
If you want 7+9 Cup I send me a message ,i have a set with Tires .
harald
Assuming both wheels have 55mm offsets and are wearing 255/40/17 tires, there will be slightly more tire bulge on the 8" wheels. As for the rims, the 9" wheels will extend 1/2" farther from the car.
It would be very difficult to tell the difference at a glance.
