964 Forum 1989-1994
Front Hood Shock????????
Old Jun 17, 2002 | 11:00 AM
c4cab0's Avatar
c4cab0
Question Front Hood Shock????????
What is the procedure for replacing the front
hood shock? How do you disconnect the lower
attachment? Thanks for the help.
Old Jun 17, 2002 | 04:44 PM
Jay H's Avatar
Jay H
Post
If I remember correctly, the bottom of the front hood shock just snaps off it's mount. You may want to get a long screwdriver to fish down near the bottom of the hood shock and pop the bottom off of it's ball type socket. Pretty easy once you know how. Typical German engineering. Looks impossible, turns out to be easy...
Good Luck!
Jay
90 964
Old Jun 17, 2002 | 05:25 PM
mj964's Avatar
mj964
Post
Jay is right - a long flat blade screwdriver works perfectly to pop the old struts out at the bottom. I found the new ones snapped on the ball mounts without tools; the spring clip is forgiving enough that you can just coerce them on by holding the strut at the top and pressing gently against the lower mount. They pop right on.
I looked at the new struts in the Performance Products box for months, wondering how I was going to change them. The entire process - both sides - took less than 15 minutes.
Good luck!
Mike
'91 C4
Old Jun 17, 2002 | 07:11 PM
gregC2's Avatar
gregC2
Post
There are Porsche hood shocks and some "lifetime" hood shocks; which to get and how much are they (only need fronts).
Old Jun 17, 2002 | 11:51 PM
Jay H's Avatar
Jay H
Post
I've always used OEM hood shocks and have had good results. Fronts about $12-15 each and rear deck lid about $7 each.
Jay
90 964
Old Jun 18, 2002 | 02:35 PM
horst's Avatar
horst
Specialist
Post
A year ago, I replaced w/ OE. Now ready for another pair. The next ones will be "lifetime"
Old Jun 19, 2002 | 12:47 PM
c4cab0's Avatar
c4cab0
Talking
Thanks for the help. I have replace engine
cover shocks but not the front. I am tired
of using my head for the hood prop.
Old Jun 19, 2002 | 01:12 PM
Fred, Long Island's Avatar
Fred, Long Island
Post
Somewhere I have seen a fixture that lets you gang two struts together. Even two worn struts on one side have enough left in them to solve the problem. I jury-rigged two on a previous car and it worked fine.
Question: Are the rears pop-offs too on the 964???
Old Jun 19, 2002 | 05:55 PM
Jay H's Avatar
Jay H
Post
The rear deck lid shocks are the typical pin and clip mounting. Just like the previous generation shocks. The rear deck lid on the 964 uses the same shocks as previous 911's do.
Old Jun 22, 2002 | 12:09 AM
Karl F15's Avatar
Karl F15
4th Gear
Post
Just changed my front hood shocks - one trick - tie a piece of thread to the clip before popping it off, until its back on...if it drops down the hole, your 15 minute job just turned into an hour. (No I didn;t drop it...this time!)
Old Aug 4, 2002 | 09:57 PM
USCGMoose's Avatar
USCGMoose
Question
Anybody have a good source for "lifetime" replacement hood shocks? Any idea on price? I've seen 911 hood shocks for cheap but the 964 ball and socket type always seem to be way more expensive.
I too am tired of using my head or a dowel rod to hold up the hood.
Old Aug 5, 2002 | 08:29 PM
USCGMoose's Avatar
USCGMoose
Exclamation
By the way, I just changed my rear deck shock and I found two things:
1. I couldn't get the "lifetime" weltmeister shock to fit. It was too thick to fit into the area on the deck designed to accept the shock. The shock head was about 1 CM thicker than the OEM part making it too wide. I had to engineer around this.
2. Tying the thread to the clip is a great idea. Not only does it help you recover a dropped clip, it also makes it easier to hold the clip without getting your fingers in the way of the pin.
Still would like some advice on the front shocks. My OEM shocks aren't doing the job and I don't want to change them every couple years.
By Verdad Gallardo | 2026-04-28 19:00:17
