Fuel Tank Pressure Test
Like many of us, I have been chasing a fuel odor issue in my trunk and interior for a while now. So far, I have replaced the fuel filler neck with the updated part, replaced the gas cap, and cleaned the carpet. All of these items have definitely helped, but I can still smell some fuel inside the cabin in the mornings. The smell seams to be stronger when the tank is full.
I have seen posts referencing a fuel tank pressure test that is recommended to diagnose leaks in the system. I finally got a round to trying this test over the weekend. I drilled a hole in a spare gas cap and inserted a brass air fitting in the hole to make a tank-pressurizing tool. After checking the cap for leaks, I then hooked my homemade fuel-tank-pressurizing tool up to my air supply and fuel tank with a pressure gauge. When I tried to pressurize the fuel tank with a few pounds of pressure via the filler neck, the system would not hold pressure. I tried to find the source of the leak by squirting soapy water on all of the tank hoses that I could access. Unfortunately, I could not find the leak. Then I thought the air might be escaping from some sort of pressure valve in the system.
Does anyone know if the system is completely sealed, or if I need to plug a valve somewhere to perform a pressure test? Thanks in advance for any help.
Technical Specialist
Lifetime Member
Lifetime Member
Andy,
Another action which I did helped the fuel smell, and that is to replace the activated charcoal cannister. It's located in the left rear wheel well behind a cover, just in front of the tire. The part number has been superceded to a 993 part number, 993.201.221.01. In addition, I find if, in the garage, I leave the windows open a crack, that for the most part any gas smell is no longer an issue.
Technical Guru
Originally Posted by Indycam
If the fuel tank was sealed , when you drove the car , the tank would have to implode .
The test you are doing is something I would not suggest to my worst enemy . Gasoline and compressed air equals a bomb ! Think , 747 center tank ! If the thing blows up in your face , you will look like micheal f,ing jackson .
anewbill,
Have you checked the suction hose and fuel filter gasket on the bottom of the fuel tank? You have to jack the front right side of the car up and undo the fuel pump cover to get to it (all you need is an M10 socket). If you've checked everything up top it's worth a look and only takes a few minutes.
Thanks for the replies. Don't worry Indycam. I only used 1-4 PSI to do my test, but I will be very careful with compressed air and gas in the future. Very interesting, analogy to a 747 center tank.
I have not checked the suction hose and fuel filter gasket or the charcoal canister yet. I will plan to investigate…
A question remains…
So, it sounds like there is possibly a bypass valve that prevents the system from sealing completely? If so, how can a difference in pressure to "hear" the leak be achieved? Should I be able to pressurize the tank to 3 PSI and hold that pressure if the system is performing correctly?
Thanks again for the help!
A question remains…
I have a very sensitive snif tester and have still not been able to find the minor leak that is causing the smell in my trunk.
BTW the 747 exploded because of poor shielding on old wiring harnesses that ran through the tank. A short created the explosion.
Its all about one thing $$$$$$$.
Technical Guru
How do you get fuel out of a sealed tank ? Will it not implode ?
If you pump air into a gas tank that has a leak , what comes out is gas fumes just like a unlit torch .
If this sounds like a good test to you ...
I sometime smell the fuel odour when the tank is fuel is running low. I'm sure that I've not got a leak though, as sometimes when I open the fuel filler cap, you can hear air rushing into the tank. Is this right or do I have a problem?
Thanks!
Thanks!
Jarhead
The tank can't possibly be completely sealed or it would certainly implode as the fuel was pumped out. But I think Jason's right too, because it would seem to be somewhat sealed. Maybe there's a one-way valve, that helps to equalilze the pressure when it gets too extreme. Just spitballing here.
Brian
Brian
