rear undertray for 1991 911 3.6 C2 Cab.
Originally Posted by bhensarl
Here we go again...
Brian
Brian
Yeah... I wonder where the market is for these things... even if I sold mine for half at $700 I'd make out like a bandit - it just drips oil on the concrete behind the garage!!!
I not only took the engine cover off I took off the side and rear engine tray pieces and the engine breaths much better. I left on however on engine tray piece that kisses the clutch housing area.
1990 C4Cab
1996 C4S
1990 C4Cab
1996 C4S
Technical Guru
You might want to reconsider putting the rear & side engine tins back in place. Without them you have extremely hot air coming off the catalytic converter and very hot air coming off the primary & secondary mufflers that gets sucked into your intake. The engine cooling fan is also blowing that already heated air through the heat exchangers and over the top of your motor. You'd rather have the air coming from outside and above at ambient temperature instead of superheated by your exhaust. If your rear tin is removed what did you use to connect your heat exchangers to the engine cooling fan?
Technical Specialist
Lifetime Member
Lifetime Member
Funny thing, last week I took my car in for a major service at a local independent shop, it went in without an undertray but came out with one on! I went back and asked why they put it there and the lame excuse for fitting another customers undertray was that they thought I would like it! Like it, I almost fell over laughing, that was until I found my airbox broken, the bottom clip missing, the brakes had air in the lines, the PDAS was not bled because they did not have a hammer and some engine surround bolts missing! That the short of the sory I dont want to go into the story about how the mechanic was trying to convince me you dont need a hammer to fully bleed a C4 system....I have an undertray you can have if you want it.
Aside from arguements about what the undertray does or doesn't do, another thing worth thinking about is the cost you pay your mechanic to remove it and replace it every time they do any work on the engine - I guess it adds up over time................
Jamie,
Good point, I remember seeing "remove/install power unit cover" on a quote and thinking I need not pay that because I dont have one, I seem to recall it was a significant number.
Youcef
Youcef
That's amazing they charge for its removal - you need one tool - a 10mm socket, and there's only 10 or so screws to remove!!!
Do they charge to get in and out of your car to pull it on the lift, too?!
