Who has the most beautiful 964 on here??
#586
Have moved both fronts and rears out since that photo was taken but the fronts have some rubbing issues on tight turns so I will need to push them back in a little. Lowering is another thing on the list but that can wait until I have all the paintwork sorted.
#587
It depends if you have the right tire combination, and the right size spacers.
#588
What spacers did you use to have caused the rubbing?
#589
Think they are 32 or 35, they were the ones that were on the back originally so I simply swapped them over. There was always a chance that they would push the wheels out too far but I wanted to try them before buying another set. Keep in mind that my car was a narrow body car which has had the wide body fitted to it by a previous owner and being a C4 I can't simply swap the suspension to the outer mounting points.
#596
The most beautiful 964 on here
This is my '93 964 Turbo 3.6. First owner car in Polar silver with Marine blue
interior, full PSH with all the documents from '93 till now. I love that colourcombination
