964 Forum 1989-1994
timing chain housing gasket
Old 06-07-2004, 08:15 AM
dutchcrunch
dutchcrunch's Avatar
Default timing chain housing gasket
hello,
1990 c2 , the gasket that goes between timing chain housing and engine case. i know that it is aluminum, but does it have rubber on the inner edge to help seal. like the chain tensioner cover plate. thanks
Old 06-07-2004, 08:26 AM
dutchcrunch
Default chain housing gasket
hello again,
better yet, does anyone have a picture that they could post of the gasket that goes between timing chain housing and the engine case.
thanks
Old 06-07-2004, 12:25 PM
axl911
axl911's Avatar
www.msroadrace.com has a good collection of technical diagrams.
Here is one for the timing chain housing.
http://www.msroadrace.com/TechStuff/...Two1-03-06.jpg
anthony
Old 06-07-2004, 12:47 PM
vuugti
vuugti's Avatar
I just replaced these gaskets this year. The change is rather involved if you have A/C, you'll have to dremel a hole to access one bolt. Additionally, the part numbers have been changed, they are now the same gasket for each side.
Cheers,
Andy
Old 06-07-2004, 06:39 PM
dutchcrunch
Default gasket no 7 from anthony
hello,
not the cover rubber gasket. the one that anthony referenced and it is gasket no. 7 . by the way i know of a guy that sell the actual left and right gaskets that you are referring to Andy, and they are factory german parts. the web site is www.hdrogers.com p/n's 964 105 181 01 and 964 105 182 01.
Old 06-08-2004, 09:54 PM
RonnieM
RonnieM's Avatar
I have one that I got from Pelican that has the rubber around the inside lip. I tried to post picture but can't get it to go through.
Old 06-08-2004, 11:31 PM
dutchcrunch
Default gaskets
hi Ronnie,
good lookin out, from your discription i can figure it out. i just wanted to know if it was all metal or with rubber too. you answered my question. THANKS!!!!!!!!!!!
Old 05-14-2009, 11:57 PM
vernard
3rd Gear
vernard's Avatar
HI Andy,
Do you have a printed guide on changing the cover plate gaskets? I'll loosing every bolt hat hold the engine Tin in place and I can't get the small plate in front of the cover out. Any info greatly appreciate. 95 993
Quick Reply: timing chain housing gasket
