Bizarre noise from shifter area
Background:
I installed a sleepers short shift kit a few months ago and have been very happy with it as I like the feel and am able to get the shifter closer to me so its more comfortable. I originally installed the OEM version, however the issue this caused was that with the shifter now raised, the leather boot was quite tight - tight such that I could feel it tugging when shifting into 2nd or 4th gear. I decided, therefore, to switch to the billet version of the kit.
Spent some time last night installing the billet version and then took it out for a test drive. When I shift to 5th, I get quite a loud noise coming from the shifter area - its hard to describe but I guess I would describe it as sounding like something metal is in contact with something spinning (like a drive shaft)? Doesn't sound good at all. I can minimize the noise by pushing the shifter up and to the right more, although it doesn't completely go away. Directly related to speed and not RPM, no change with clutch engaged or not.
I tried to do some troubleshooting this morning and pulled the center console apart again. Since the only thing I changed was the shift lever I reverted back to the OEM version and went for a test drive with everything open. I don't really hear the same noise in 5th, however it does seem remarkably loud with the shift boots and center console removed - has anyone driven around like this in a C4? Is it always this loud or do I have some kind of bearing issue somewhere?
Anyways, when I reverted to the OEM style shift lever I notice that the OEM version of the kit has a slightly wider area that the two plates bolt to - I don't know if the billet versions narrower machining causes something to interfere down below, but I can't think of what would be interfering. In any case, I swapped back to be billet version again and drove with everything open again - its definitely better than before, but 5th is still loud. I put everything back together to see what it sounds like with the boot on and its still substantially louder than when I had the leather boot/OEM shifter.
Anyone know whats going on here? Could this be torque tube bearings? For those who have the swine reboot, do you notice an increase in noise?
Thanks,
Tom
Thanks,
Tom
Hello Tom,
I just did a Rothsport and fd forward/golden rod install, with the swine eleven boot, etc.. on first installing everything it was the other side for me......when in Reverse....the bottom of the shifter (wider than oem) hit the shift tunnel. . . just enough to ride on it. What might be happening is your shifter way over in 5th is using your shift tunnel as a sounding board, amplifying the rotational noise of your drive train. When in R and 5, do you see if the shifter/linkage is clear of the sides?
Hi Tom,
I have the sleepers kit with billet and swine11 set up on my c4. I'm having trouble understanding your description of loud. Would you mind taking a short video and posting? My car is coming off the lift tonight so if I have a moment i'll take and drive and try to understand what you''re hearing.
Background:
Thanks,
Tom
Thanks,
Tom
PM me and maybe I can help out.
Thank You,
Gary Castillo
Sleepers Speed Shop
964Luftballoon (03-11-2022)
Hello Tom,
Hi Tom,
Thanks for the video. I went on a drive this weekend and tried to listen for the same type of sound. Unfortunately, with my primary and second delete it's loud so I didn't notice anything out of the ordinary. I specifically tried to listen for anything grinding when I went into 5th. I'm curious to see what Sleepers response as they asked you to reach out to them.
Update: I'm quite confident after shimming the shift lever this is not related to the short shift kit, but rather the removal of the leather shift boot and a bunch of sound damping from the OEM shifter has uncovered a different, more concerning problem. I'm going to flush the trans and diff over the next few days to see if that makes a difference in the noise, but in the absence of that correcting the problem does anyone know how to diagnose torque tube bearings? Anything else I should be looking at? CV joint boots all look good and intact.
Cheers,
Tom
Cheers,
Tom
Cheers,
Tom
Cheers,
Tom
1) Wheel bearing failure
2) "Gunk" or something in the transmission that can be fixed with a solid fluid flush
3) Front differential gear or bearing failure
4) Torque tube bearing failure
5) G64 gear or bearing failure
I plan to address 1 and 2 later this year and will report back any progress.
Tom
Not yet. For mine I have the following potential theories from easiest to solve to most difficult:
Tom
Tom
Not yet, I'm slow. Car is in a thousand pieces for a suspension overhaul but getting close to re-assembly. This included new wheel bearings so I'll see if that worked relatively soon and update this thread.
Cheers
Tom
Cheers
Tom
Also uncovered that my diff seal is leaking
