Ruf C2 Front Lip (Splitter) Installation Question
Does the Ruf front lip splitter go on over the existing black plastic valence panels or in place of?
Here is a link to the item in questions:
http://www.rennspd.com/P_Detail.asp?PID=429
Probably a stupid question, but I am puzzeled.
Pat Caulfield
91 C4
Pat Caulfield
91 C4
I bought Rennspeed's RSR 2 piece splitters instead of the Ruf front lip. Both of them mounts under the factory valance using the existing mounting points. Being that they are fiberglass parts, hand fitting is required.
I've not installed mine yet, but I can already tell that fitting the splitters will be easier with the help of my Dremel tools.
Bill Gregory gave a quick write up about a year ago when installing the Ruf splitter and confirmed that it mounts over the existing parts. The only mod was to use the longer screws supplied by Ruf.
Rennspeed's description seems to confirm a similar installation:
BTW, I ordered this part from Rennspeed and will have it mounted by next weekend. I can post a follow up if anyone's interested.
Duplicates of Ruf one inch straight down front spoiler lip, mount under 964 C2, C4 factory black plastic valance.
Super Guru
Originally posted by PC2
I bought the RSR two piece splitters.
Originally posted by RSAErick
Peter,
That looks great so far. I can't tell from the pictures, but did you first remove the stock lower plastic valence?
Erick
Peter,
Erick
I will try to finish this today and post more pics. I still need to get it painted because it has only been primed.
Ps. Warmfuzzies, I think it will look awesome in Gurads Red!
Originally posted by Ruairidh
Peter - that does look very very good - where did you get the "door sill trim" from?
