964 Forum 1989-1994
Warning about 90 C4 on the market - VIN WP0AB2961LS450167
Old 08-20-2020, 11:44 PM
  #31
964Luftballoon
964Luftballoon's Avatar
Has anyone reported his listing to eBay for vehicle misrepresentation? If i'm not mistaken it's in the listing policies that you must list the VIN. While it's up to potential buyers to perform their own due diligence and not buy on emotion. However, it could be helpful and save someone from making a huge costly mistake?
964Luftballoon is offline
Old 08-21-2020, 09:21 AM
  #32
cobalt
cobalt's Avatar
Received 2,062 Likes on 1,238 Posts
I am currently removing the sunroof from my car by installing a factory roof panel. They are crazy stupid expensive $7600 list. Since we are as my friend puts it filleting the roof of I am quite in tune with how panels and seems should look. It is far more complicated than some videos show and takes a lot of patience measuring and in our case fixtures to do properly.
I am not sure if this is the same seller that sold the black 90 C4 on BaT a long while back to a friend but this car has the same screw holding the rocker on so I suspect it might be. If it is I say run he had the same argument how he knows cars and in the end the car was completely misrepresented.
It is mentioned that this is a rare factory sunroof delete car although I am not so convinced. Form my experience this car has had at least one rear quarter panel replaced and possibly the entire roof skin. This is pretty apparent from the pictures despite that the car is white and one of the hardest colors to see detail from pictures
This picture clearly shows the remnants of the tab from a replacement panel. This is actually present on all 964's but when they left the factory the tab is cut off so it can't be seen. This is a huge mistake that body shops that don't know these cars make leaving the tab on and cutting it off later leaving visible remains behind. A proper cut tab should look like the ones I pictured as you can see it is a straight cut and is well inside the framework being completely invisible from above. I have more than a half dozen factory original 964's to compare to at any given time and I have been very careful to inspect cars for this. Anyone who claims otherwise is being less than truthful. Also it would need more careful inspection but appears they welded a new roof skin to the old without properly separating the old panel from the lower panel. This should be a clean single panel line showing and not show any layers but as I said needs further investigation. I would be curious if this was a factory sunroof delete car as it would be only the third I have seen and quite rare but I suspect the current skin isn't what left the factory.
cobalt is offline
The following 4 users liked this post by cobalt:
964George (10-09-2020), 9SIX4-C4 (08-21-2020), BLACK3.2 (08-21-2020), kricci (08-26-2020)
Old 08-21-2020, 10:23 AM
  #33
Spyerx
Spyerx's Avatar
Received 1,790 Likes on 1,089 Posts
The options sticker is intact on the car and In good readable condition and unmodified. It Does not list option 650.
it’s possible it has had fender replacements
given how original the car is, despite its issues, i would highly doubt the roof panel, even if it was replaced, was not delivered that way.
Spyerx is offline
Old 08-21-2020, 03:00 PM
  #34
Noah930
Noah930's Avatar
Originally Posted by stutt911
Love the rusty screw
God, that's beyond terrible. That's not even trying. You can buy a good used sharkfin for about $60 from Autobahn if the tabs on the underside have broken off. I would be disappointed if the $60K car I just bought showed up with that Mickey Moused repair.
Noah930 is offline
The following 2 users liked this post by Noah930:
911Jetta (08-24-2020), paddlefoot64 (08-22-2020)
Old 08-24-2020, 02:50 PM
  #35
997Pilot
997Pilot's Avatar
It’s now on hemmings, of course no mention of the complete poor state it’s in.
https://www.hemmings.com/classifieds...4/2425701.html
997Pilot is offline
Old 08-24-2020, 04:24 PM
  #36
Deserion
Deserion's Avatar
And no VIN, of course.
Deserion is offline
Old 08-24-2020, 04:38 PM
  #37
Vegas993
Vegas993's Avatar
"God, it is fast"... indeed, It will hang with a new Camry in 1/4 mile!
Vegas993 is online now
kricci (08-26-2020)
Old 08-24-2020, 10:32 PM
  #38
911 jared
911 jared's Avatar
Some pics i have when it was for sale in San Diego. Before the touch ups.
911 jared is online now
Old 08-24-2020, 10:53 PM
  #39
Spyerx
Spyerx's Avatar
Was it parked outside For years Sitting at the ocean? I’ve never seen one like this. It’s not normal for a ca car....
must have been right on the coast...
Spyerx is offline
Old 08-24-2020, 11:04 PM
  #40
spartansix
spartansix's Avatar
That is an impressive amount of corrosion. I can't even imagine what it looks like under the fenders.
spartansix is offline
Old 08-24-2020, 11:15 PM
  #41
Marine Blue
Marine Blue's Avatar
Even $30k is questionable for this coupe, that is a significant amount of corrosion.
We can’t argue that the seller has spent some money to repair some of the car although without receipts and detailed pictures it’s difficult to confirm the quality of the work. Based upon the most current pictures it’s also clear that the cosmetic work done was very much focused on the surface only which means there’s rust lurking throughout this car.
Marine Blue is offline
Old 08-25-2020, 02:14 AM
  #42
stutt911
stutt911's Avatar
i saw the car after the lipstick was put on it, and indeed it’s all just surface “coverup” nothing even professionally done. I also didn’t realize the engine was leaking so bad because the cover was on , which adds to the bill because this seller surely didn’t do any engine work it it or reseal it , this car is a PIG that not only needs a complete glass out body restoration but seems that at minimal it will need an engine reseal and you’re still left with a 165k mile C4 at the end of all that.
It really puzzles me how the seller doesn’t disclose any of this when he knows it, downright scummy flipper.
stutt911 is offline
Old 08-25-2020, 07:47 AM
  #43
cobalt
cobalt's Avatar
I know of a C2 tip that sold for $6k that had some bad rust but nothing this wide spread. This reminds me of the old Jeep Wranglers that you would see in the 80's on Nantucket or Block Island just barely holding together. Looks like it had the rear quarter was replaced a long time before these photos, most likely the entire side was repaired resulting in all the rust due to poor prep work. Even Hank Moody would be embarrassed to drive this one. Not sure Singer would take this one on. LOL I suspect there is even more going on that isn't right that we can't see.
cobalt is offline
Old 08-25-2020, 09:53 PM
  #44
Spyerx
Spyerx's Avatar
Maybe it was washed with ocean water?
this car has been consistently registered and passed smog since 96 in california. Smog checks are every 2 years or on sale. You can see one 4 year gap. So it’s not like it sat for a massive time not being driven....Unless it’s fake / forged checks.... which on a car like this would be unlikely.
the level of corrosion is just bizarre for a ca car
Spyerx is offline
Old 08-25-2020, 10:16 PM
  #45
Marine Blue
Maybe it was parked on the beach or driven on the beach regularly? Looks more like a UK or Upstate NY car to me.
Quick Reply: Warning about 90 C4 on the market - VIN WP0AB2961LS450167
