CCU Fault Code 45 and 32
So I dug into the servos this afternoon and it looks like the right and left mixer servos are working. Is it possible the CCU can throw an error code in error? I thought code 32 indicated that I had a bad servo motor but it looks like the motor still works. I cleared the error code a couple of time but this one keeps coming back. What am I missing?
The internal servo motor shorts and make a burn mark on one spot of the travel. Next time it reaches this spot it will be stopped and the CCU will store a fault code.
You need to either change or refurbish the servo in question.
Cheers,
Tore
Cheers,
Tore
Got my new fan today and Porsche clearly changed the design
![Name: photo899.jpg
Size: 1.59 MB](https://rennlist.com/forums/attachments/964-forum/1309586d1570888187-ccu-fault-code-45-and-32-photo899.jpg)
Also tested current draw on calibrated 12v. Here is the old design
![Name: photo564.jpg
Size: 1.40 MB](https://rennlist.com/forums/attachments/964-forum/1309587d1570888251-ccu-fault-code-45-and-32-photo564.jpg)
Hand here is the draw for the new design
![Name: photo557.jpg
Size: 1.38 MB](https://rennlist.com/forums/attachments/964-forum/1309588d1570888297-ccu-fault-code-45-and-32-photo557.jpg)
