RS belt covers - mounting?
Im looking to retrofit some RS belt covers. I had installed my RS carpet without these (due to NLA 964 and excessive $ for genuine 993 parts).
The factory correct solution for mounting these covers are welded studs (but I’m not sure which size). Given that my carpet is already in place, would a rivnut or rivstud be the next best solution and what screw size? Is there anything behind this area I should watch out for if drilling?
Technical Guru
Many thanks! Is T5 and M5 thread?
I think I may cap discharge weld the the studs. My understanding is the heat is minimal and localized to the base of the stud, but I'll trim the carpet a fair bit wider and mask it off.
If you decide to weld you might consider using this stuff it does work miracles.
Technical Guru
^^^^ The Spida looks interesting, better than some of the kits i have seen and no doubt pricey. The kits I have seen aren't cheap for the lesser quality but amazing where things are heading.
No doubt pretty soon we will get around in self driving, robotically built, glued together composite & alloy, electric vehicles.
If you don’t fancy welding, you could bond these on with something like Sikaflex :
http://rotaloc.com/products/bonding_fasteners/
https://www.uksealants.co.uk/sikafle...ant-300ml.html
or if the baseplate is big enough, pop-rivet them instead.
I'm leaning towards simply drilling for rivnuts (or a metric rivstud if i can find one). I think the drivers side is clear to drill the holes. Does anyone know if the oil tank is not too close on the passenger side? 10-15mm of clearance is probably required and care to not pass the drill bit through.
Formerly turbotwoshoes
Drilling into the chassis
If I am not mistaken, aren't you going to be drilling into the lower portion of your car? That is where the warm (hot air duct is inserted into the ducting/chassis part of the car.) There is a tube, much like a dryer vent behind that part of the wall. Just my $.02
Thought I'd update this belt cover "retrofit" project - I had the Capacitor discharge studs welded in with existing carpet remaining in place. Little touch up paint where I dremeled a hole in the carpet to the chassis.
Left the vents out for now as I'd probably have to cut my carpet. The edging should probably run behind the vent but I installed the carpet a bit too low.
