993 ignition coils in Place....wowww
My original coils failed and replaced them with the silver Bosch units- One of which promptly failed in less than three months... i’ll be using a 993 units for this reason alone.
Pete
Pete
If you just lay all parts (bracket, coils pack, etc) on the bench you will find out easily the best way to mount the 993 pack,
I used a 8mm drill to drill two holes so the coil will fit the black bracket and front bracket (coper colored one) will connect the coil on the left side.
I used a little lock tide to secure the nuts.
Tip, put some tape om the position you need to drill to prevent 'skitting', first dril with e.g. 3mm drill a hole before using the 8mm.
