964 Forum 1989-1994
Front bumper respray, rubber trim question
Old 06-17-2019, 05:12 PM
jellonailer
jellonailer's Avatar
Default Front bumper respray, rubber trim question
Recently pulled my front bumper to have it repainted and give me access to the oil cooler and a/c resistors, added the 2.2K ohm resistor hack too.
See picture - not sure of the best way to install the rubber bumper trim piece. Remove rivets on the metal part install and re-rivet or jam the trim piece under the metal lip without removing rivets? Anyone have any tips or tricks? Thanks
Old 06-17-2019, 05:22 PM
Vegas993
Vegas993's Avatar
The rivets are still available. I removed the plates for paint. The easiest way to refit them is to rivet the plates back on with the rubber strip in place. It’s very hard to get the strip in place if you attach the plates first.
Old 06-17-2019, 07:31 PM
jellonailer
Thanks. So I assume you can "peel back" the rubber flange to get the pop rivet gun in place - head of rivet is on top and "pop" barrel is on the bottom.
Old 06-17-2019, 08:21 PM
Vegas993
Vegas993's Avatar
Correct, it’s easier than it sounds.
Old 06-18-2019, 08:44 AM
cobalt
cobalt's Avatar
Received 1,987 Likes on 1,195 Posts
The trick to installing the smile with the plates in place is to start on one side and catch the opening with the leading edge then pull the rubber smile across the bumper to snap it in place. (i hope that made sense) If you try to attach them by just pushing the entire opening over the plate at once you will be in for a battle.
Although I would tape off or remove the plates for painting.
Quick Reply: Front bumper respray, rubber trim question
