I don’t see many threads on the installation of e-power steering pumps so I will document my installation.
Steering rack installations have been covered before, so I will leave it at - I replaced the 964 rack with a 993 rack for no other reason than I wanted to.
Dawes in Pennsylvania makes a great bit of kit for the 997 pump and I will be using it for my installation. I will document as I go along.
993 steering rack and Rothsport rack brace.
Hoses from the Dawes kit.
Drilled holes to the frunk.
The Dawes “pump bracket/cup”.
And this is what it is supposed to look like when completed...
With the engine in, removing the old mechanical steering pump is a pain in the neck to speak mildly. I couldn’t have done it without a lift. But I got it done and plugged with the Rothsport aluminum cover.
Today I basically only took care of removing all the old lines. Tomorrow I will wire the pump. One wire to ground, one wire direct to batttery (with 80 amp fuse) and one wire to switched power on.
