Engine out- while I’m in there advice/Parts list
In preparation for my 6 speed install I thought it wise to ask the greater good to help me make the list of “while in in there” parts and maintenance. My car has just over 100,000km’s on it. I’m mostly interested in the stuff that really tough to do with the engine in the car. This will be my first time to drop the assembly so hit me up.
Starting with the obvious maintenance:
I’ll do a compression test before pulling the engine
plugs
valve adjustment
new clutch/pressureplate/rmsbbslave
maybe sparkplug wires
Replacement items:
Engine pad
Ok- as you can see I have a lot to learn here....
Pete
plugs
valve adjustment
Replacement items:
Engine pad
Pete
This is a huge slippery slope. Wisdom will say: replace all rubber and gaskets that are impossible to get to while motor in. Fuel lines that are rubber.
etc etc.
Why are you pulling the motor?
etc etc.
Thanks for the replies thus far.
Whats the advantage of uograding the injectors?
Yes fuel lines will be added to the list. How about the fuel pressure regulator? Is that accessible with the engine in?
Spyrex- I’m pulling the engine just to switch out the 5 speed with the 6. Also clutch etc is original so good excuse to throw in the Rs hardware. Also the point is to address all those little seals etc. Honestly one of the main reasons is to familiarize myself with the whole system.
I come one from a bmw background- 20 some odd years of BMW 2002’s to be specific. I know that car inside out and can fix anything on it. I have a good Porsche mechanic but I’m a believer in the idea that no one can know a car as well as the one who spends the most time with it.
Truth be told I’ve wanted to pull the engine since I got the car- why? I’m extremely curious. But I’ve held off until I’ve had a real reason to do so.
In in all likelihood it will be late fall before I do the deed. I want to have as much prepared as possible as I’m in Japan- land of the 200% markup- I order most of the parts from back in the U.S. And I just want to drive it during the good seasons.
So- what seals etc are we talking about here?
Pete
Pete
Front and rear main seals, timing chain cover gaskets, replace the power steering belt, grind your AC bracket, oil breather and temp sensor manifolds ? gaskets,
Clean, clean, clean.
Spend $100 and r&r all these gaskets and sensors while its out, easy peasy. Can be a PITA otherwise.
Many good threads and experience here on RL.
I've already done lots of research on fuel lines. Surprisingly, most of the lines from the rails to the FPR etc are hard poly lines with a rubber jacket and hold up very well. We already did some destructive testing of a couple of mine to check their condition.
The one that fails routinely, and that is the highest on the list for proactive replacement, and it is not said "poly line" is the one that is at the fire wall, connects the hard line from the fuel pump, and goes to the fuel filter. It is also under high pressure. I replaced mine again (it had been done at some point before my ownership).. I used Cohline 2240 hose for this, which is rated for all fuels and has a temp. rating of -40 to 257 degrees F.
IHI KING!
You should also inspect your engine tin for rust. I replaced some of mine during an engine rebuild. I had it powder coated with the rest so they all matched. What engine mounts are you running? If they are sport (RS style), now would be a good time to have your engine cross bar reinforced.
Pete
Pete
And yes, do the FPR.
OK, so I did the following, and this is toward the fully comprehensive list, and I'm not recommending all this to everyone, as there are lots of differing opinions on how far to go, thresholds for pain, etc. Oh and I have not shown the new P/C's (I had the early model and wanted to upgrade) or aluminum timing boxes...
- ALL the sensors (O2, flywheel, knock, Cylinder head temp, etc.)
- Fuel pressure regulator
- Injector ultra sonic cleaning
- Vacuum connections (the little maccaroni's, and three-ways),
- Intake sleeves, intake sealing rings,
- Breather hoses, breather housing gasket,
- Oil lines to and from tank and oil filter console
- PS pump belt and seals off the cam,
- Timing box seals (all of them) - this source of leaks is coming on all 3.6's, when, not if....
- Valve covers (aluminum) and gaskets
- Timing chain tensioner gaskets and bridge o-rings
- New starter
- New alternator
- Replated all fasteners, pulleys halves and spacers, fuel rails, clamps, etc. etc.
- Powder coated engine tin, engine carrier and fender supports
- Air Conditioning bracket mod (cut out inside radius to ease removal in the future)
- New belt sensor
- Distributor belt
- Spark plugs and wires, caps and rotors
- Fuel line mentioned above, and fuel filter
- PS reservoir hoses, and new reservoir (screen gets plugged)
- Clutch
- Clutch hydraulics (slave and slave hose)
- Engine pad
- Axle boots and CV repack
- Probably lots of other stuff I forgot already...
Rennlist Site Sponsor
Jon from EBS Racing here If you do not already have a parts supplier I would be happy to provide you with a complete price quote on your parts list. Also, we ship to Japan daily and can offer some very competitive rates. PM or email me your parts list if you are interested. We can also help with any tech questions you might have.
Thanks!
Jon
phone: 775 673 1300
jon@ebsracing.com
4068 S McCarran Blvd
Reno, NV 89502
Thanks!
Jon
phone: 775 673 1300
jon@ebsracing.com
Reno, NV 89502
Jon
EBS Racing
Reno, NV 89502 USA
jon@ebsracing.com
http://www.ebsracing.com
We can answer your Porsche questions with live customer support from 8 AM to 5 PM PST M-F
(775) 673 1300
Jon
EBS Racing
Reno, NV 89502 USA
jon@ebsracing.com
(775) 673 1300
New hose about to go to the hardline...
