Ok now that I have this in PPI - what do you guys think?
#32
The real pros please correct me but I wasn't aware you could just add a gasket to a non-gasket engine. Unless that's not what you mean by gasket fix. My UK '90 was rebuilt 5yrs ago without a gasket fix and it's just fine
#33
c2 vs c4 - they drive very very differently... not good/bad just quite different
make sure a c4 is what u want... have you driven well sorted examples of each?
#35
If you're fine with the condition of the paint on this car then I say buy it. Throw in $5k for maintenance and you're looking at $55k for an ROW C4 which will be sound mechanically. If you're unhappy with the paint condition or the fact it's a C4 then I would probably skip and keep looking to avoid the headache of painting.
#37
I bought my car from them back in 2015. Pm me if you want.
#38
It depends how you look at it. I have an early 90 c4 on original motor at 80k miles without the gasket and it leaks a single drop every month or two, which doesn't bother me enough to tear open the engine. However, in the case of an engine that was rebuilt I would question why it wasn't addressed? From what I've seen machining for the gasket costs between $500-750 so I would think it would be a worthwhile investment when you tear apart the whole motor (it's a drop in the bucket at that point). It's not really a necessary item, but the lack of maintenance in other regions of the car lead me to believe it was skipped for cost purposes which naturally leads the skeptic in me to thinking what else was skipped.
That would be great, thank you. PM sent.
#39
while what tarek says is accurate... the c4 is a somewhat nose-heavier, more planted version of a c2... i think the driving experience is quite different
i have two c2's (one stock one hot rodded) and a c4, mostly stock... the c2's are definitely much lighter in the nose and give the classic porsche feel of the light/twitchy front end near the limit...steering feel/effort is significantly lighter and more communicative... both cars with correct alignment and setup, the c4 stays planted and stays in understeer mode much more when pushed, esp. in slow, sharp corners, where the c2 will rotate much more easily and feels 'tossable'... the c4 will play, but you need to 'manhandle' it much more, whereas the c2 is driven at pace with a lot more 'lightness' and finesse
of course, if you live in foul weather locations and like to go on fun runs even when it is not so nice out, the c4's awd is worth its weight in gold
none of this you will feel if you just mosey along in urban/suburban traffic, or to get a latte at starbucks... but leaving aside the racetrack, if you just take these cars out for brisk morning canyon carving/windy road drives at 75-80% of the car's potential, you will definitely feel what i have described above
#40
i admit i am pretty deep into porsches and aircooled ones at that
#41
Is it not a japanese car with these rear seats?
Annoying petty defects, but nothing dramatic.
Have the offending area of paint checked thoroughly by a competent body shop.
Non sunroof is VERY important for me, and hard/impossible to find in the US. How important is it for you?
Some people love taking care of maintenance / restoring to factory spec., others want to drive and nothing else. What grop are you in?
#45
“Near perfect turnkey c4 has 1200 miles on overhaul of motor runs great and is drip free,ac nice and cold and heat works perfect,shifts smooth :updated cdr220 with iPod cable,from Becker auto sound”
From eBay listing, define near perfect turn key. A lot of items that should be addressed.
![Roll Eyes (Sarcastic)](https://rennlist.com/forums/images/smilies/rolleyes.gif)
