Steering wheel question... 930S wheel into 964
https://www.pelicanparts.com/More_In...MaAmdoEALw_wcB
For a 930S wheel as per above... will it mount directly onto the factory 964 steering wheel hub? Will the horn work? I have read on some post an 'ATIWE' hub is needed... but this is a stock Porsche steering wheel, no?
Getting a new (to me) 964, have done a couple of Prototipo's with Momo hub which robs arm reach clearance... thought I would try something different for this car.
Also, anyone happen to know what is a diameter of stock 964 steering wheel? Aftermarket Momo's are usually 350mm which is notably smaller than stock... blocks view of gauges...
930 wheel is made by Atiwe, best way to mount this is to use momo 7004 hub and an adapter to mate the steering wheel to momo hub. I sold my 930 wheel a while ago and still have the adapter if you are interested.
I have a Ruf wheel made by Aitwe, it came with all of these parts but I believe this is what you would need...
This is the Atiwe offset spacer for gauge visibility: https://www.fvd.net/us-en/100498ATI4...tiwe-15mm.html
Hub https://www.fvd.net/us-en/1004981729...tact-ring.html
Horn Contact: https://www.fvd.net/us-en/100498F601...ng-wheels.html
Edit...
Actually, FVD list the Momo hub at Size: 7.87 x 5.12 x 5.12 inches and the Aitwe at Size: 5.12 x 5.12 x 5.12 inches. If those measurements are correct, without the spacer, the Aitwe is over 2.5" closer to the dash. And about 2" with the spacer.
https://www.suncoastparts.com/product/SKU964SSW.html <--- another option... says it is a wheel made my Momo, so I assume uses Momo adapter, so same issue
Are there other options that get the wheel mounted closer to the dash?
seriously... so do you happen to know if the 930S wheel is a 350mm wheel? or bigger?
FVD says the 930s is 360mm
https://www.fvd.net/us-en/100498F601...stitching.html
See my edited post above, the Aitwe hub is shorter according to FVD.
You install a bridge plug in the center console that disables the airbags.
https://www.fvd.net/us-en/9286122200...le-bridge.html
Here is is how I did it: 2.7 Ohm resistor for bypassing airbag
thanks vegas - this sounds like worth a try
looking at nardi wheels too
I just measured it for you, from the clam shell to the back of my wheel is 4.25" so those FVD measurements are off. Maybe someone with a Momo can measure theirs.
The bridge plug can be had for around $35 and takes about 5 mins to install. Personally, my OCD would not allow me to run a resistor knowing there's an OEM part for it, lol.
